TV COBY LEDTV5536 Horizontal lines
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    Hi
    T-Con board or bad panel?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: TV COBY LEDTV5536 Horizontal lines
    I would say panel.
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      How do I test a t-con board, because if the panel is bad the tv is garbage
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        A Tcon wont cause that failure all it does is decode the Lvds signals, so its either your Mainboard or more than likely Lcd panel.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Sharx112
          ASUS VA27EHE randomly unstable
          by Sharx112
          Hello community. I've got an ASUS VA27EHE with a Panda LC270lf1l01 panel that started to behave strangely. A bit of intro:
          If you power on the monitor without any inputs it turns on, displays the ASUS logo, shows no signal and goes into standby normally. When you plug it via HDMI sometimes and more recently, most of the times, it distorts the bios logo with horizontal lines, then when loading into windows 50-50 the windows emblem also is in horizontal lines. And after the system loads it almost always works properly, lol. On some rare occasions a part in the top of the monitor is being distorted...
          03-26-2025, 03:42 AM
        • mmartell
          General Questions on the Relationship Between Mainboard, TCON and Panel
          by mmartell
          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
          01-06-2024, 01:32 PM
        • Kikerumbo
          Mi Curved Gaming Monitor 34" - Horizontal lines
          by Kikerumbo
          Thanks in advance for any help you can provide.
          I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
          After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
          03-14-2024, 02:48 PM
