LE37M88BD Possibly Bad Lcd ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello all deciding weather or not to buy this faulty Lcd Tv for £30 I have not yet seen it in person however the symptoms of failure are as follows:
    Red tint to every image displayed.
    Bar running across top of display.
    Image is vertically separated by small black bars all 1cm apart.
    What do you guys think this could be I am aware that this uses and Auo panel with As15 Ic which could cause the Red tint and small black bars. However the bar across the top could this be a Lcd driver pack failure ? Meaning this will need a new screen never seen and As15 fault cause this.
    Let me know what you think cheers chaps.
    Image of failure:
  • zomi
    • Nov 2011
    • 509
    Re: LE37M88BD Possibly Bad Lcd ?
    The bar across the top looks like bad panel to me
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Tbh looking at it I think its a mix of both, as only the red sub pixels are working that suggests As15 failure and I have seen an As15 cause the 1cm black bars across the screen as well. But the horizontal bar I think is Lcd failure either way dont think its worth the gamble.
      • wills123
        • Jan 2014
        • 72
        • england
        If you sell parts it's worth a punt, if you don't I wudnt gamble on it, they suffer tab bond problems terribly
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yeah I repaired pne of these panels which if my notes are correct is a T370HW02 for tab bonds ages ago, however this looks more like a driver failure. Im buying it anyway just to see only paying £10 for it.
          • wills123
            • Jan 2014
            • 72
            • england
            Nice, worth a punt at that for sure but I am a hoarder lol, I have a shed full of sets cheap/free that are for spares, mostly old obsolete stuff but handy sometimes
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Cheers haha I work from home or my moms house as im only 16 and my bedroom is full of tvs lol, I used to work for another local company but things happends and I left them do better on my own haha. Shes dropping it around in a bit I will start testing and see what I find
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Got the tv here and as I predicted its a combination of failures. The As15-F Ic is failed, the Ic is burning hot and the gamma reference voltages are out some do fluctuate from 0-3v every so often which isnt good, As15 failed. Also if I flexed the Lcd the bar across the top would come and go however pressing on thhe tabs doesnt seem to solve it, so panel is also trash.
                Im going to replace the failed As15-F which will be the fourth one I have done this week ! Then sell the Tcon which is fetching about £30-£50 on ebay. Panel and Tcon are Auo no wander they failed. Junk !
                Thanks for reading.
                  AUO aren't too bad in my opinion.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    They are ok have seen quite a few Auo Lcd glass fail. These panels which are also used in Le37R88bd which is the tv I have in my living room do have good image quality, color and contrast wise. Also seen the 42" version of this panel fail on an Lg as well.
                    • Akira81
                      LG 55LF652V-ZA flashing led bars despite their replacement
                      by Akira81
                      I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                      If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                      Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                      04-14-2023, 11:50 AM
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      The TV does not turn on, the standby indicator is on. All voltages are present.
                      Emms is dead. Not readable, not detected.
                      Replaced emmc.
                      But with another dump there is no launch
                      Terminal log
                      UART
                      AC_ON
                      RPMB key is not yet programmed
                      HASH1_VERSION=0x00000000 64bit
                      E-B
                      FDE enabled
                      layout pattern onebin by SAR7,0...
                      06-01-2025, 02:11 AM
                    • ctroxtell
                      Carrier HK50AA063 display controller common failure help
                      by ctroxtell
                      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                      02-05-2025, 05:31 PM
                    • howardc64
                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                      by howardc64
                      Problem
                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                      Model & Board Pics
                      Conflicting Spec
                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                      https://www.shopjimmy.com/vizio-gj-2k1...
                      10-10-2024, 01:16 PM
                    • CapLeaker
                      LG 65UQ70 horizontal bars jumping
                      by CapLeaker
                      So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                      Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                      I guess this one goes back either later today or tomorrow morning, unless...
                      08-13-2024, 09:41 AM
