HELLO.
I NEED YOU OPINION ON THIS PLASMA TV WITH NO VIDEO.
THE TV LOOKS TURN BUT, THIS IS THE FACTS:
1. I DON'T HAVE LED ACTIVITY ON LOGICAL BOARD.
2. VS_ON SHOW 0 VOLTS.
3. 15V ARE GENERATE LIKE 5VOLTS STANDBY.
4. CAN RUN PROCESS SELF TEST BECAUSE NOTHING SHOW ON SCREEN (PATTERN COLORS PROCESS)
THERE IS A PROCEDURE FOR FIND A SHORT.
When troubleshooting, It's very important to first check Vs, Va, Vsc & Ve
If Vs is missing (0V), disconnect power and check for short. Use ohm meter to measure resistance while disconnecting Y-Board & X-Board supply feeds one at a time.
Turn Power On and Test SMPS with short connector removed for correct Vs voltage verification. (It may only come up briefly but to full level). Again be careful not to reconnect Power Connectors until Vs falls below 10V.
Dump questions.
The leads of the multimeter need to be one vs and the another on ground, right? on power supply?
after that need disconnect x-main board?
what do i expect?
thanks
