Samsung HP-T5064 image retention issue
  • freakaftr8
    • Oct 2012
    • 3743
    I've had this TV sitting around my house for almost a year now and the problem was usual buffer board failure taking out the ysus and MOSFETs on ysus. I replaced all and got it working finally but I noticed a great deal of image retention. It does go away and all present voltages are accounted for and I've checked the Yramp and Vsetup and Vsetdn adjustments against an o scope and all seem to be within range. Oddly I've done some research on the internet to find out that this particular model is very well known for having image retention issues. Vs voltages are normal and vscan is right on par.
    This retention issue will present itself if there is an image on the screen for longer than 10 seconds once the image changes you'll see the shadow for a good 30 seconds to a minute afterwards. I can't really sell this TV like this and I've tried putting it in different modes and lowering contrast and brightness ranges to find out its still there. With all voltages being present and accounted for do you think this could be a possible panel problem? And all the plasma TVs I have worked on in the past years I have seen image retention but it goes away immediately. This one sticks around awhile. There is no maldischarge in the picture is flawless otherwise.
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung HP-T5064 image retention issue
    X Sustain problem ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I had this issue try upgrading the firmware it sorted mine.
        09-07-2024, 05:50 AM
      • shlomim412
        samsung ua55es6800 - no image
        by shlomim412
        hi
        having problem with samsung ua55es6800
        tv had backlight on, sound working - responds to the remote control but no image.
        check tcon board - had 12v in but no other voltages present.
        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
        when leaving only left side connected - again no voltages and no image.
        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
        kept trying to block less pins on the left ribbon cable...
        05-15-2024, 05:00 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
