17MB35-4 3.3V Shorted Help ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello all, I have here a 32" Lowry Tv rebadged Vestel junker. The failure here is that the standby led comes on red (standby) then goes blue (on) then shuts down back to red, what is happening is the Psu is going into over load because the mainboard is shorted. I had one of these 17MB35-4 with the same failure and never fixed it. The whole 3.3 volt section is almost completely shorted to ground very little ohms, this is abnormal. Here is what I found:
    U121 Reg shorted in circuit however tests fine out of circuit.
    U132 Reg shorted in circuit however tests fine out of circuit.
    C308
    C293
    C290
    C284 Ceramic capacitors all show shorted in circuit however test fine out of circuit.
    All fuses are good, which isnt good because it means that the fuse has failed to protect the circuit hence Psu going into shitdown.
    I cant seem to fond what part the voltage stops at as it shuts down too fast. Any help or ideas on what to test are greatly appreciated. Thank you.
    Re: 17MB35-4 3.3V Shorted Help ?
    Have you replaced the PSU? What model PSU is it?
    I bet I know what the problem is (it's got me before.)
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hi mate, the Psu I dont think was replaced however the guy has had the back off its a 17PW26-4 Supply. It surely cant be the Psu as I have swapped these around with the same main board before and again had the same failure months back on the same board on a 42" Hitachi which was never opened, the 3.3v section shorted on that :L
        If the wrong power board is installed 5V & 3.3V will be shorted at the power board causing a blinking LED and failure to power up. Usually does not cause damage despite 3.3V rail being at 5V (protection circuit catches the fault quickly, which is nice of Vestel I suppose.)
        You need to remove a jumper between 5V & 3.3V on the power board. It's a small surface mount zero ohm link. I can't remember the part number but it's right next to the connector.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Tom, the 3.3v rail going to the mainboard is shorted to ground 5v is fine. I am 90% sure its not the Psu that caused this.
            OK, didn't realise it was a ground short. If 3.3V is shorted to ground then it is probably a bad CPU or other component like HDMI receiver shorted. Not an easy fix.
            You can try powering 3.3V using an external PSU and seeing what gets hot but otherwise you're probably going to need a new main board.
            Maybe you'll find a shorted MLCC. I had one of the 17MB62 boards with about 5 ohms between 3.3V and ground, I believe it was power surge damage on HDMI input but may also have been a random CPU failure.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm thanks for the info Tom Going to try that tomorrow, will put 3.3v into the this I think you might be right as the lowest point of resistance seems to be from the Hdmi processor 22 ohms to ground on the 3.3v input to it which isnt normal.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Quite certain that the Hdmi processor is at fault now, not only is there super low ohmage it almost looks like there is a blister in the centre of it :L Hmm going to look into this more tomorrow. Already had enough of Hdmi chips today after fixing a Panasonic with a Hdmi processor related issue earlier. Will update you tomorrow on what I find.
                  • 31007
                  i had this, it took forever to find.
                  it was a shorted ceramic cap.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Cheers Stj do you remember the part number ?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Also that Hdmi chip is not the lowest point of resistance there is a ceramic cap checking lower however out of circuit it checks fine, but sort of happy I can nearly rule that Hdmi processor as not being the issue. Stj do you remember the part number of that cap cheers ?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Here is an image of this board, I know its crappy contrasts however just sent if you could highlight or tell me where that bad MLCC was cheers.
                          • 31007
                          that's a different layout, but it would be in the psu section lower-left in your foto.
                          strangely yours seems to be missing most of the parts!
                          i will tell you how i foud it.
                          i made a list of all the caps on the 3v3 rail,
                          then i hooked my meter to the 3v3 and gnd set to continuity with the beeper on.
                          then i just lifted and put back each part with the air-station till the meter stopped beeping.
                          and that's why it takes forever!
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Nice one cheers Stj
                            • wills123
                              • Jan 2014
                              • 72
                              • england
                              Not sure if it helps but I used to fault find xbox360 shorts by jumping a pc psu always on then jumper wire affected rail and either smoke or very hot component usually made it fast to find problem
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Cheers Wills going to do that now This thing is bumming me out as removed every single MLCC and all test fine so something else is up hmm time to keep diagnosing.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Well wouldn't you know it would be the last thing I checked, the flipping Hdmi processor is at fault, didn't even need an external psu to determine that this thing was getting very very hot, it burnt my finger haha. I removed the processor off the Pcb and the tv now behaves normally. The Psu completes its self test and the short on the 3.3v rail has gone, upon pressing the power button the standby light goes blue but after about 10 seconds the tv shuts down this is because the Cpu is detecting that the Hdmi chip is not present.
                                  Now time to try and find this:
                                  Sil9185AC1U
                                  0951
                                  AG03KX2
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Found one for £3
                                    http://www.ebay.co.uk/itm/1-Piece-SI...-/400331089328
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Now I know before any one says its a difficult solder job, I have been able to replace a scan Ic with success which has a lot more pins so think I should be able to do this. Going to order an Ic and let you all know thanks chaps
                                        • 31007
                                        does it have a pad under it?
                                        • mr.Data
                                          Shorted inductor means short circuit? Asus ROG Gaming laptop.
                                          by mr.Data
                                          I have a dead Asus ROG gaming laptop with liquid damage. When I measure the first mosfet, there is 19V. On the second mosfet there is nothing on the input and 4.3V on the output but it is not continuously. It is going up and down.
                                          I have read this article:
                                          https://www.prospace20.com/2022/03/h...ad-laptop.html
                                          Is it through that inductors can never be shorted?
                                          I have 2 inductors near the GPU that are shorted. Does this mean that the GPU itself is shorted? How can I know for sure?
                                          11-15-2022, 04:31 AM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • Durenth
                                          DC detection circuit failure on Subwoofer
                                          by Durenth
                                          First of all sorry for my English and for my poor knowledge in transistor behavior, I'll do my best to be clear…
                                          I have a problem with the DC detection circuit of a Panasonic 40W Subwoofer, model SW-P270.
                                          The relay in the DC detection circuit never turns on thought there is no DC in the audio output signal.
                                          Output signal is ok, controlled with an oscilloscope.
                                          I found the service manual (full board schematic attached to this post) and measured the voltage as shown below, pink is the expected value indicated in the manual, red...
                                          11-27-2020, 10:17 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
