Panasonic TH50PZ80U - power button
  • ultimatt
    • Apr 2015
    • 29
    Re: Panasonic TH50PZ80U - power button
    Another question, for the fuse that failed can it fail due to an overload condition or short within the TV itself or can it only fail due to an overload or short from the main AC power input?
    • ultimatt
      • Apr 2015
      • 29
      "Another question, for the fuse that failed can it fail due to an overload condition or short within the TV itself or can it only fail due to an overload or short from the main AC power input?"
      to clarify, the power (ac) board only connects to the main power board. The main power board also has a couple of fuses.
      What I am trying to determine all conditions which could cause one the two fuses on the power (ac) board to fail?
      I am trying to determine how to run a start up procedure since I don't know what if any faults this unit has.
      Thanks.
        The best thing to do is plug the TV in and watch it
        Fuses can sometimes blow without obvious cause. If it pops a fuse again, there could be another issue. For example PFC circuit might be malfunctioning causing higher RMS currents.
        • themosttogain
          HP Envy 13-BA1565na with intermittent power button
          by themosttogain
          Hope someone can give me some suggestions on this because i'm at my wits end with it...
          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
          07-12-2024, 03:03 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • TimeRabbit07
          Asus FX517ZC charges but power button does nothing
          by TimeRabbit07
          Hi all!
          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
          Here are its various numbers and identifiers:
          Model short: FX517Z
          Model long: FX517ZC-HN114W
          SN: NANRCX01S57842E
          CN: 3SDB 12M
          MFD: 2022-10
          Motherboard model: DA0NJLMBAE0 REV E
          Symptoms:
          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
          History so far:
          The...
          09-04-2024, 05:48 PM
        • reessi
          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
          by reessi
          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
          No corrosion any where!
          Tried a replacement power button off ebay and the same.
          Very occasionally it will work with the power button connected!
          Same results with or without the battery.
          Can it be a fault with the Audio board or the mainboard?
          The touch Id assembly connects through the Audio board first then to the Mainboard.
          Flex...
          06-26-2024, 03:31 PM
          03-31-2024, 02:12 PM
