Sharp LC-40LE550U no backlight
  • krygods
    • 257
    This TV powers on and off and I can see the floating screen saver very faintly with a flashlight.
    I've measure voltages and here is what I've found
    CN201
    1 - 3.25VDC
    2 - NC
    3 - 112mVDC
    4 - 3.19VDC
    5 - GND
    6 - GND
    7 - GND
    8 - GND
    9 - 12.45VDC
    10 - 12.45VDC
    11 - 12.45VDC
    12 - 12.45VDC
    13 - 375mVDC and rising???
    14 - 3.18VDC
    15 - 0.67VDC
    16 - NC
    CN202
    1 - 329VDC
    2 - GND
    3 - 275VDC
    4 - GND
    5 - 221VDC
    CN203
    1 - GND
    2 - 168VDC
    3 - GND
    4 - 116VDC
    5 - GND
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sharp LC-40LE550U no backlight
    Originally posted by krygods
    CN201
    3 - 112mVDC
    14 - 3.18VDC
    It would make things easier for us if you put the description of each pin next to the readings.
    CN201
    pin 3 - ACD
    pin 14 - BL_ON
    On most sets, BL_ON (backlight on) going high (> 3) means turn on. On some sets, it might be the opposite.
    ACD might be AC Detect. On some sets, ACD high might be needed to turn on. Or it could be the opposite.
    When the TV is in standby mode, what is the voltage of pins 3 and 14? When turned on what is the voltage of 3 and 14? When the set is turned off, what is the voltage of 3 and 14?
    Wow, 329V DC into the LEDs. Nearly a 55 to 52 volt drop between each strip of LEDs. At least it has decent 47uF 450V cap there.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      pin 13 is NC. The 357mV reading is just your multimeter on high impedance with some ghost readings. NC is probably not connected to ground otherwise you would get 0V.
      • retiredcaps
        • Apr 2010
        • 9271
        If the TV is in a very dark room, do the LED backlights flash even for a brief time?
        • retiredcaps
          • Apr 2010
          • 9271
          Hmm, from
          https://www.sharpusa.com/ForHome/Hom...C40LE550U.aspx
          4 million: 1 dynamic contrast ratio
          Without even seeing the TV, I think I will call
          • retiredcaps
            • Apr 2010
            • 9271
            BTW, what is the marking in IC UD101, just right of 47uF 450V cap?
            • krygods
              • 257
              P/N for UD101 is RT8300
              • krygods
                • 257
                disassembled the panel to test the leds, found bad solder joints on one the of the connectors that join the two separate strips into one long strip. turned it on and the leds blinded me.
                • CapLeaker
                  Leaking Member
                  • 8208
                  perfect!
                    So how many LEDs are in one strip? 4 LED strips?
                    • krygods
                      • 257
                      I believe it was 10 LEDs per strip 5 strips
                      • krygods
                        • 257
                        crazy thing is that four out of 5 led strips are mounted to the panel casing which is plastic, only the second strip from the top is mounted on a strip of metal. I was under the assumption that the LED strips needed to be mounted to metal which acts as a heatsink?
                          They should have good thermal management, I would set the BACKLIGHTS LEVEL (not the brightness/contrast) to as low as you can so the LEDs will run cooler and extend the life of the LEDs.
                          • krygods
                            • 257
                            ok cool, i'll go ahead and set it to a comfortable low level before it goes to a new home.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              The datasheet for the above has a FLT pin which detects open/short LED. Monitoring this pin for it going low points you to the LEDs as being suspect.
                              • Markpixley
                                • Aug 2012
                                • 37
                                So I have the same problem, found two of the led connectors that needed resoldering...still no backlight...my voltages on CN202 CN203 are all pretty solid (with the exception of voltage dropping to 80 volts at the bottom of CN 203) (which is quite a swing if you ask me from 329v to 80v)...at any rate...
                                Checking UD101...pin 6 is the fault...I get 12 volts on Vin and 12 volts on Fault which seems to point to the leds again...also now that I've re soldered the leds I do get 10v on both pin 13/12 (led 1/2) but zero volts on pins 10/9 (led 4/3)...any idea what I should see there or do I go back and take the panel apart yet again and search through the led connectors...really cheaply designed solder joints for the connectors...not much effort to knock them loose...
                                  You are seeing the Voltage to the LED swings all the way up to 329V because there is no load due to open circuit (either by bad connector or the LED has open circuit, when the circuit see that high Voltage that is above the normal operating level then the over Voltage shutdown kicks in then it drops down to 80V which is the Voltage that is fed into the Boost converter circuit to drive the LED strings.
                                  • Markpixley
                                    • Aug 2012
                                    • 37
                                    Ahhh thank you, back into the panel to check it will let you know what I find...great forum by the way!
                                    • Markpixley
                                      • Aug 2012
                                      • 37
                                      Ok I have physically checked each and every LED with a diode test they all gave me OL one direction and .889 the other, I also checked each and every connection with a continuity test and everything came back ok...
                                      Voltage with reference to ground (negative clip on metal ground Meter set to DC) goes from 340, 286, 233, 180, 128...there are 5 strips with 11 led's each...
                                      But no back light...is it possible that this unit needs some kind of factory reset since it did have a faulty connection on one LED strip?
                                      Would the UD101 go into LED fault and need to be reset somehow? Thanks in advance...
                                      • Markpixley
                                        • Aug 2012
                                        • 37
                                        I also have another question since i have never seen these before, but what is the clear diode looking fuse item labelled SG105 in the bottom right hand corner of image #2?
                                        Is it some sort of slow blow fuse and if so is there a way to test it? It seems to connect ground planes on the back of the psu...but I am unfamiliar with it.
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Misterfixit
                                          Sharp LC-58Q7330U No Backlight
                                          by Misterfixit
                                          This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                                          06-04-2023, 07:39 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Misterfixit
                                          sharp LC-50LB601U No backlight
                                          by Misterfixit
                                          I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
                                          04-04-2023, 01:21 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
