47LG5010 Tcon or panel Very hot ribbon
  • london-freddie
    • May 2015
    • 472
    Hi everyone more help needed please
    this one is a 47LG5010
    when I got this tv it would power up to a dark blue screen only, no picture no sound.
    My first thought on it was tcon or mainboard
    changed mainboard no change still powering on to a very dark blue screen
    moved on to tcon board and found that one of the ribbons from the panel to the tcon was very very hot, other ribbon cold
    Disconnected hot ribbon and powered tv, it fired up to half a picture on screen.
    Anyone any ideas on this have swapped ribbons left to right same both connected no power up disconnect right hand left hand powers up to a picture.
    I must say the right hand ribbon gets very very hot very quick
    I may be wrong I am no expert but to me this must now be tcon or the panel itself
  • london-freddie
    • May 2015
    • 472
    Re: 47LG5010 Tcon or panel Very hot ribbon
    tcon board with ribbon disconnected, half picture on screen, if I reconnect the ribbon no picture at all
    • budwich
      • Jul 2015
      • 3097
      my guess is that one of the panel drivers on that side of the panel is in trouble... :-(
      check along the lower edge of the panel to ensure the edge boards (if any) are not touching the frame or other metal parts.
      • london-freddie
        • May 2015
        • 472
        found this on panel driver board looks like C27 is the problem,
        • vinceroger69
          • Mar 2012
          • 6714
          possibly shorted out maybe worth measuring the same capacitor on the left side and replace it with the same.
          • london-freddie
            • May 2015
            • 472
            measuring c27 in situ is measuring same as all the other caps on left and right boards
              There should be trace on the bottom side of the board that makes the connection to the top side of the board for that filter cap C27, same for the C15, 16, and 28.
              Does the top terminal of C27 has electrical connection to the top terminal of C28?
              The bottom terminals fo C15, 16, 27 , and 28 are all connected to the ground plane.
              What is the resistance reading of that C27?
              • london-freddie
                • May 2015
                • 472
                thanks for that yes top of c27 has connection with top of c28
                bottom of c27, 28. 15 and 16 are all connected to ground
                • vinceroger69
                  • Mar 2012
                  • 6714
                  as per budms qusetion post 7 What is the resistance reading of that C27?
                  • london-freddie
                    • May 2015
                    • 472
                    what scale do you want me to measure c27 in
                      200 Ohms SCALE, or AUTO. Just to be sure to report if the reading is in Ohms, K Ohms, or M Ohms.
                      • london-freddie
                        • May 2015
                        • 472
                        0.03 on K Ohms all caps reading the same
                          That is very low Ohms (30 Ohms).
                          Remove that C27 and take the resistance reading again between the two pads where C28 was installed.
                          • london-freddie
                            • May 2015
                            • 472
                            will do please give me an hour or so need to pick kids up from school, will post asap
                            • london-freddie
                              • May 2015
                              • 472
                              ok removed c27 trying to measure it now, however just powered tv up with c27 removed and both ribbons connected
                              picture on the previously bad side of screen is now perfect and flex is not now getting hot, however picture on other the other side previously ok is now all red vertical lines, doesn't make sense to me
                                That is the filter cap so you should replace it and see, you will probably has to remove C28 to check the capacitance to see what the capacitance is, also check the DCV on the C28 before removing to see what DCV you have so you can will what the cap Voltage rating will be (the Voltage rating will have to be higher than the measured Voltage).
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  The reason you also may be getting those lines because if you take a look at your first picture the ribbon cable has a burn mark going all the way through it you might have to replace that ribbon cable and then also check to make sure that the connectors on both the t-con board and the panel are not burned.
                                  Try swapping ribbon cables from the good side to the bad side and see if the picture looks normal on the opposite side also
                                    Good eyes!
                                    • CapLeaker
                                      Leaking Member
                                      • 8222
                                      Originally posted by budm
                                      Good eyes!
                                      better than mine!
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Lol I had to look twice and saw it.
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • Helikvar
                                          Hisense 58A6KV
                                          by Helikvar
                                          No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                                          . Backlights also light up when tv is powered on.
                                          Removing panel ribbon cable from left side screen still dark.
                                          Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                                          . Tcon gets 12 volt
                                          . Tried taping...
                                          02-21-2025, 03:52 PM
