e701i-a3 no picture but backlights
+ More Options
Posts
  • tjmethod
    • Jun 2013
    • 137
    Re: e701i-a3 no picture but backlights
    Originally posted by freakaftr8
    I don't believe the panel will technically show anything if both driver boards are disconnected. at least one side must be connected in order to display the trailing horizontal lines that a control. Due to the fact that this effect is not built into the vertical drivers like other panels
    You are right I definately dont want to buy anympre t-con boardsl- do you or anyone got a line on where I can buy transister with a bit stronger values like the sony one you found. I also need that silver capacitor- both of these are blown on 2 of the 3 boards I have- I hadnt tested one that I know at least has the blown COXA. So from what I have read earlier, it is i fact the panel blowi g the Coxa… and the silver capacitor?. Has your or anyone tried a new or good powoer board since the power boards have the LED inverter on them and whats your thoughts on that?
    • freakaftr8
      • Oct 2012
      • 3743
      Actually the panel is blowing only the transistor. The capacitors are ok.
      The power supply on these sets are quite hardy. If its got backlight and powering up the power supply and mainboard is ok.
      The primary problem is one or more side drivers fail and overload the tcon. In turn that COXA transistor seems to be the failure
      • tjmethod
        • Jun 2013
        • 137
        Two of my t-cons I tested after the fact had no reading on the silver capacitor in dc mode like you said. Any idea what could be blowing my silver caps? If I get another good or repaired t-con in, should I try disconnecting the lower left first or or just get a beefier coxa- the specs you gave me earlier- from what I recall, sot 23 n-channel 45v 2a- I couldnt find anywhere online… I am thinking I can find the cap. Do you know the specs on the one that came out of the sony you had in your stash?
        • freakaftr8
          • Oct 2012
          • 3743
          The capacitors are ok. Trust me. I only mentioned testing the voltage across that silver cap because if there's voltage there than the COXA transistor is ok and the t-con board is providing all voltages required to operate properly. The silver capacitor is just a test point
          • tjmethod
            • Jun 2013
            • 137
            Ok… since the transister is blown is why I get no reading on the cap?
            I am trying to find a beefier transister- do all the following fit the specs you had mentioned earlier? The last one is 3a- will that handle more power?
            • freakaftr8
              • Oct 2012
              • 3743
              Okay the reason you get no reading on that cap with a blown transistor is because it's shutting down the voltage in the board. With that transistor shorted all of the voltage is beside the 12 volts going into the t-con are now shut down. Like I said before I use that capacitor is a testing point to see if the transistor is good and the rest of the board is putting out proper voltages.
              I as well are looking for a suitable transistor replacement for you guys. Stay tuned
              • freakaftr8
                • Oct 2012
                • 3743
                Found it coming out of China unfortunately but this is the one that I used
                QF which is a RTR020N05 2a 45v n channel SOT-23 style mosfet
                m.alibaba.com/product/60290702860/RTR020N05-020N05-MOSFET-N-Channel-SOT.html
                • tjmethod
                  • Jun 2013
                  • 137
                  Yup RTR020N05 comes back to a 45v 2a n-channel sot-23 made by ROHM, I ordered 20 that just shipped from TX under $13 and $4 shipping- should have them Thursda.…
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Ok great!
                    • Tmal0146
                      • Oct 2015
                      • 18
                      • Usa
                      #50
                      Hey guys. So I'm new to this forum. But I have the same problems as listed above. I have audio, but no video. Backlight is still coming on, but I have no picture. All I have when the TV is powered on is a dull very faint blueish screen. I am not very experienced when it comes to working on TVs but I have done a lot of research on this issue with this model TV. I have read every comment on this thread and I'm going to walk through this to make sure I understand correctly what needs to be done to "fix" this TV. I have the back cover and sides off and I have unplugged the small white ribbon on the bottom right corner of the screen. I now need to replace the tcon board or the transistor that is blown on the board and with the white ribbon that is feeding the side driver boards unplugged I now need to power on my tv to see if it is in fact the right side drivers that are defective. Once I decide that I'm on the defective side. Do I simply just peel the gold looking ribbons from the panel and remove both of the driver boards from the side that I determine is defective? Is there anything else that has to be done to make it work? I will post a couple pictures if needed.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Sounds like you are right on par!
                        • Tmal0146
                          • Oct 2015
                          • 18
                          • Usa
                          #52
                          Awesome! Thanks a bunch! Next question is. Where is a good reliable place to buy a tcon board?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Lol honestly I can't tell you. I believe a lot of these sales outlets are selling rubbish t-con boards that were deemed as panel failure but the boards were okay. Yes they are half correct the panels did fail however it took out the boards with them and what I have found is purchasing these boards most of them are already failed. Your best bet would to repair your board.
                            If you don't have the means necessary then it's a gamble wherever you get the board from.
                            before you connect the board to the panel just connect the LVDS cable. From there you can read voltages on the board following earlier posts to make sure the boards working or not before you connect it to the panel
                            • Tmal0146
                              • Oct 2015
                              • 18
                              • Usa
                              #54
                              Ok. I'll try to grab one from somewhere and do exactly that. I really appreciate the help and I'll take pics and update the thread on how things end up going.
                              • 12345lonestar
                                • Oct 2015
                                • 4
                                Originally posted by tom66
                                If the transistor is not yet bad, you may be able to power it up with the ribbon removed as Freak stated. If that is good then try the surgery on the panel, removing the ribbons. Please note - this is a last resort. It is not a reversible operation. If you do something wrong, the TV is not fixable past that point.
                                Not sure if this ha been covered but I do not recall. So if you remove the cable form the side driver boards, wouldn't they be disengaged and not cause the issue anymore? So why does removing it completely change anything. Since they are already unplugged. Just wondering why removing it is necessary to complete the repair. Jut want to understand whats going on.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Because if they're still connected to the panel they're dragging down the opposite side drivers which is causing them an abundant amount of load too much that they can handle by themselves which in turn will burn those out. Also the panel cannot drive those tabs without the power being connected so they will drag the panel down causing it to be dark on that side. Plus the reason they are being removed in the first place is because one shorted we can't have that connected to the panel.
                                  • Tmal0146
                                    • Oct 2015
                                    • 18
                                    • Usa
                                    #57
                                    I wondered the same thing but just assumed something like what Freak says.
                                    • 12345lonestar
                                      • Oct 2015
                                      • 4
                                      Agreed. You can replace a coil but I would use a dvm in diode test mode. Although you can achieve results with your meter you can't have the power on while you do this.
                                      Here's a thought. Just test power at this point. If you have 24v or so the + side of the silver round capacitor on the left side of the board in the picture your ok. Test it like this turn your voltmeter to DC voltage and use the red lead against the plus side of that capacitor the black lead against one of the screw lug terminals on the tcon board. If you have voltage there the rest of the board is functional and you can use it.
                                      I tried this test with my T-con and got 0 voltage. Is this indicative that there is something more wrong with it than just the MOSFET chip? Should I just get a whole new t-con board rather than replacing the MOSFET?
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Well is there a short showing up in the COXA transistor?
                                        • 12345lonestar
                                          • Oct 2015
                                          • 4
                                          I tested the resistor and it did not appear to be shorted. I got normal readings from it. So I was a little surprised when I did not receive any Voltage on the silver round resistor from this test. But I am having the blank screen issue. I tried disconnecting the white cable from either side and nothing changed. Still blank black screen. But everything else points to it being the bad horizontal video driver.
                                          I was originally going to replace the resistor on my t-con, but now i'm not sure what is damaged on it since it failed the test but the resistor does not appear to be shorted. I suppose Ill buy a new T-con and see. Ill buy some resistors too since many of them seem to be damaged on the boards being sold online.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
