Samsung LN52B750U1F colored vertical lines issue
  • tvguy2015
    • Sep 2015
    • 23
    I've had my Samsung LN52B750U1F for about 6 years now and then all of sudden the other day as I watching TV the left side of the TV developed these colored vertical lines. It was exactly 50% of the screen while the right side was perfect. The lines seem to be on every input and on top of menus, etc. The picture in the background looks fine.
    Then last night as I was watching the TV the other half developed the vertical colored lines as well. So now the whole TV has the vertical colored lines.
    Is this due to a bad Tcon, capacitor, etc. or is it my panel going bad? It seems like the picture is perfect and there is some sort of bad connection causing the lines similar to watch you get from computer monitors if the cable from your desktop to monitor was not in all the way? This also reminds of the rabbit ears when getting local TV and you had this interference until you turned the dial to clear the picture.
    So I'm hoping someone can give some feedback on what is the issue here and hopefully it is not my panel, but a simple fix like just changing the Tcon board. I've attached a picture to what the TV looks like now. Thanks.
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Samsung LN52B750U1F colored vertical lines issue
    The only clear way to know if it's bad capacitors is to remove the rear cover and inspect for bulging capacitors if none then check the cable between the tcon
    If it's connected good and the issue remains then it's likely a bad tcon board
    Others may have other bits of advice to offer
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • tvguy2015
      • Sep 2015
      • 23
      So can I rule out a bad panel here and just either the main board or Tcon?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Firstly lets take the cover off and reseat all connectors going to the screen. The chances of the panel are low but still a possibility.
        • tvguy2015
          • Sep 2015
          • 23
          Are these the two flex cables at bottom of Tcon board that connects to panel? Or am I suppose to reseat all connectors from main board as well?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Try reseating everything just to be sure it looks like a missing Lvds pin to me. Try that and let us know buddy.
            • tvguy2015
              • Sep 2015
              • 23
              Where would this missing lvds pin be on the main board? I have attached pics from the back of the tv for the 3 boards. I did reseat the organe cable going from the main board to the Tcon board and it did not help. Do you think it could be a soldering issue on the main board where if I heated it it will fix the issue? I've read quite a few posts here and other places that suggested that and it worked for them. Any feedback would be helpful.
              • tvguy2015
                • Sep 2015
                • 23
                Here is the pic of the tcon boad with the metal cover removed.
                  Access the service menu (put TV in standby and press Mute - 1 - 8 - 2 - Power on the remote in sequence) and find the test pattern option. Try the various patterns, including Before/AfterDDR and FRC tests, if available. If the lines disappear on one processor's pattern, then the fault lies on the other processor.
                  • tvguy2015
                    • Sep 2015
                    • 23
                    I went into the service menu and to the test pattern option with Before one as ) and After one at 0. When I clicked on either one and then moved to the right on the remote I got various patterns, but not sure what I'm looking for. I see a bunch of patterns when I cycle thorough the 2 test patterns and lines are there at the some and not there on the solid colors (i.e red, green, yellow). Not sure exactly how to diagnose this issue.
                    • tvguy2015
                      • Sep 2015
                      • 23
                      Does anyone think it could be the Tcon board? I talked to a local service repair guy and he thinks it might be the tcon board gone bad. If it is the tcon I wanted to order the board myself and replace it instead of taking to repair place where they will be charging me close to $250 for parts and labor. I can buy the tcon board for around $40. If anyone has any input on what could be the issue here that would be great,
                        Are the lines missing consistently from any set of the patterns? (There should be three pattern generators.)
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          that looks a odd fault in picture one the lines dont go through the onscreen text box you also say above not there on the solid colors (i.e red, green, yellow) so are you saying the lines go completly? can you post a picture when its on the test patterns?
                          are the lines in over or behind when you have the menu screen on the tv as ive just saw this on another site not sure how true it is though
                          ---Pull up your menu display and tell me if the distortion is in front of the menu display or behind---If distortion is in front of menu suspect main board---If distortion is behind the menu display suspect T-Con board--
                          • tvguy2015
                            • Sep 2015
                            • 23
                            I have attached pics from when I have the menu showing and also some of the Service Menu for the test patterns for both Before DDR and After DDR. Please advise.
                            • tvguy2015
                              • Sep 2015
                              • 23
                              Need some input if I need to order main board or Tcon board to fix my TV.
                              • truep
                                • Aug 2010
                                • 373
                                It may be a crack in the upper right side. Notice the lines on all test patterns, both Horiz and vert..
                                • tvguy2015
                                  • Sep 2015
                                  • 23
                                  I did not consider that up to now. Don't know why there should be any crack. Still not sure how the test patterns work and what I should be looking for.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    I was hoping tom or budm may chime in with ideas as they may of saw this fault before they dertainly have more experience than myself.
                                    • tvguy2015
                                      • Sep 2015
                                      • 23
                                      Ya I'd like to get some more specifics on my issue before I go ahead and order either a Tcon or main board. Trying to pinpoint the actual issue with my set so I can move in the right direction. From my pics do you think it is the Tcon or main board? The lines seem to be behind the menu from what I can tell.
                                      • tvguy2015
                                        • Sep 2015
                                        • 23
                                        I ran the PATT_AfterDDR pattern test and used he right arrow to cycle thorough the patterns. The lines seem to be present on the first pattern, but the rest of the test patterns those lines are not there. I'm attaching pics of the sequence of patterns that I cycled thorough here. Please advise if it is the Tcon or main board. I can also post the full cycle of test patterns for the PATT_BeforeDDR as well if necessary to diagnose.
                                        • Superluminal
                                          LG 47LV5500-UA Vertical Colored Lines/Alignment Issue
                                          by Superluminal
                                          Hi all, looking for some input on this one. I've been reading the forums for quite some time but this is my first time posting for help.
                                          LG 47LV5500-UA
                                          10 years old
                                          20,000+ hours on it.
                                          Watching TV on it last week and right while I was watching the image suddenly started experiencing the symptoms in pics. Rainbow chromatic vertical lines and alignment issues. The issue is uniform across the entire panel. It does not come and go, the symptoms are stable.
                                          Here is what I've tried so far:
                                          - Factory reset and cycle of picture options....
                                          11-19-2022, 07:41 PM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • Ancient1
                                          Strange LG TV issue : Image vertical lines in black screen
                                          by Ancient1
                                          Hi
                                          Asking for a friend.
                                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                          but here its the opposite !
                                          TV has new T-con = same issue
                                          A missing panel voltage would have global effect
                                          So , what should one do ? how can I find where the fault is ?
                                          Thanks !...
                                          02-05-2025, 03:37 PM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
