Hybrid IC IPM YPPD-J017C J018C repair
  • nanis
    • Sep 2009
    • 6
    • greece
    hi friends
    this is a try to repair Hybrid IC IPM YPPD-J017C J018C
    in my case transistor Q1 Q2 is dead by sort and the diodes are ok.
    i used 30f131 but tv not works.does anyone now if i must remove the diodes or not?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hybrid IC IPM YPPD-J017C J018C repair
    I can tell you now that solder job isnt the best. Apply flux make sure your ion is at max then redo them solder joints bud to make sure its not that.
    • nanis
      • Sep 2009
      • 6
      • greece
      solders its ok 100%
      my question remains
      transistors 30f131 is powerfull IGBTs and i do not know if i must remove the diodes or not.
      thank you for your anser
      • nanis
        • Sep 2009
        • 6
        • greece
        specifically i mean the diodes FRD1 FRD2
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          IF you are trying to repair an IPM that had Shorted devices, then the Driver-Chips and dual-transistor pairs will--Probably--be faulty also.
          Diodes don't normally fail. 30F131 aint ideal replacement--Isnt Strong Enough...
          So--Replace the Driver Chips(IC1) And the tiny Dual-Transistor pair, (IC3,4) as well as the two IGBTs with ones rated at 330V and 350A.
          Better still--just buy a replacement IPM!
          --These J017/8C/E IPM's fail in two ways. They go Short Or more often I find go Intermittent causing flashing screen.
          I dont bother trying to repair a Shorted one--Too much else blows as well as IGBT's--chuck it and start again! Try UTSOURCE or fleabay.
          Ones that are intermittent/flashing Can be repaired by replacing the IGBT's. Too much work, hassle and no guarantee of repair trying with shorted IPM!
          TELEFIX
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Originally posted by alastair e
            if you are trying to repair an ipm that had shorted devices, then the driver-chips and dual-transistor pairs will--probably--be faulty also.
            Diodes don't normally fail. 30f131 aint ideal replacement--isnt strong enough...
            So--replace the driver chips(ic1) and the tiny dual-transistor pair, (ic3,4) as well as the two igbts with ones rated at 330v and 350a.
            Better still--just buy a replacement ipm!
            --these j017/8c/e ipm's fail in two ways. They go short or more often i find go intermittent causing flashing screen.
            I dont bother trying to repair a shorted one--too much else blows as well as igbt's--chuck it and start again! Try utsource or fleabay.
            Ones that are intermittent/flashing can be repaired by replacing the igbt's. Too much work, hassle and no guarantee of repair trying with shorted ipm!
            +1
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Well done for attempting a repair though I normally would never bother. Best to buy a replacement Ipm mate.
              • nanis
                • Sep 2009
                • 6
                • greece
                really thanks both of you
                i will buy a new one
                • mockingbird
                  • Dec 2008
                  • 5488
                  Alastair -
                  Would you be able to tell me please what's better in the long-term, replacing the MOSFETs with IGBTs, or purchasing a new hybrid module altogether?
                  And are the newer hybrids sold any better quality-wise than the ones that came stock with the plasmas?
                  • mmartell
                    • Oct 2013
                    • 3189
                    I thought the concensus was these were long out of production and no longer available new unless old stock. Unless a shipping container full of these was found on the bottom of the Pacific ocean ?
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                      Lenovo ThinkPad X1 Yoga + Hybrid Dock (40AF0135AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad X1 Yoga + Hybrid Dock (40AF0135AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + Hybrid Dock (40AF0135AU) boardview and X1 Yoga + Hybrid Dock (40AF0135AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                      09-06-2024, 11:32 AM
                      Lenovo ThinkPad X390 Yoga + Hybrid Dock Hybrid (2-in-1) X Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad X390 Yoga + Hybrid Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X390 Yoga + Hybrid Dock boardview and X390 Yoga + Hybrid Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                      09-06-2024, 09:00 AM
                      09-06-2024, 08:41 AM
