Is the T-Con or the driver board defective on Sanyo DP46840
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I am working on "fixing" DP46840. When I got it, exactly half of the screen was black while other one worked just fine. I have gotten new T-Con board, and I have the same exact issue on same side. The only other thing that can cause this is defective driver board on the LCD panel, but I have never seen one fail like that. Is it possible?
    Side note: When I unplug the ribbon cable on the dead half, the black half of the panel turns white. I am not sure what to make of that.
    Thanks for your input.
    Re: Is the T-Con or the driver board defective on Sanyo DP46840
    "but I have never seen one fail like that. Is it possible? " Yes, you have bad panel, probably the TFT driver ICs on the flexible PCB but all of them has to be bad.
    But the half of the screen is completely black and no lines visible for sure, this is important info? Since it can still be bad T-CON, see example in the PDF.
    You did try reseating the flat cable between the LCD panel and the T-CON?
    What do you get if you only has one ribbon cable connected one at a time?
    "When I unplug the ribbon cable on the dead half, the black half of the panel turns white" It should also turn white if the good half is disconnected also, is that what you see?
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      After I have posted this thread, I have started to take the TV apart to get to the drivers. As it turns out, someone was already inside this TV, as every second screw that holds the metal bracket around the LCD panel was stripped. I had the dremel them out, I was very happy. When I got past the first barrier, there was tape all over the tab bonds. I have turned the TV on, and one burned out right in front of me. Oh well,...
      So, yes it is possible. After it burned out, panel gave out bars synonymous with bad tab bonds on the dark half. To the recycling you go; after I strip you for parts.
      Thanks for the reply.
      As the to your updated post: No lines bars on anything on the half in question. Pure black (dark blue with CCFL's) screen. Yes, it turned white when I unplugged the ribbon cable in questions on the T-Con. Yes, I did try re-seating the ribbon cables.
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
