Panasonic tc-p50x5 12-blink help.... please
  • pei009
    • Sep 2015
    • usa
    First off thank you for reading this post.
    So last night my Panasonic tc-p50x5 decided that it wanted to go black and leave me a nice 12 blinking red led. Needless to say the wife has now cannibalized my tv with her "amazing sows."
    I have some electrical knowhow and have a multimeter, but don't know where to start? Could it be the power supply? If do what is the test output voltage?
    Anyone who can provide ideas on what to text and how to proceed, I am greatly appreciative.
    David
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p50x5 12-blink help.... please
    I suspect 12 blink is audio so not a lot of steps to follow, Step 1 would be to disconnect the speakers at the A board if if it still 12 blinks then it's an A board fault. from there, well we'd need clear schematics to try component level or see if you can get another A board or repair by moduslinkpts.
    Don't know much about audio or 12 blink whether it can be triggered by anything else. I would hazard a guess and say A board is more likely to fail than a speaker unless a cable has shorted somewhere. Don't get much to read about the 2012 models on here.
    • tw2005
      • Oct 2011
      • 6458
      crikey , they call this an A board! things certainly very minimalistic in these last panny plasmas.
      even if this is not the fault , at $24 I'd keep one as a spare and not be upset
      these do have an issue with the PSU not waking up or loss of standby voltage. If 5v stdby is there then not this chip.
      Pretty sure the 15V line is what drives the Audio.
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
      • Mnawar27
        Panasonic CF-H2AU24EF3 bios locked
        by Mnawar27
        Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
        I need help to remove it,
        thankyou all.
        SN; 2FKCA26876...
        11-16-2024, 08:00 AM
