Panasonic TX-L32X5E picture "ghost/distortion" problem
+ More Options
Posts
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Hello Everyone
    As titled, picture stays distorted on screen, lines fill entire area when an image present and stays there for a while.
    As you can see, where "no signal" message appears picture is "ghosting"..
    Same when "source selection" tab is shown on screen.
    Any ideas??
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TX-L32X5E picture "ghost/distortion" problem
    Are you getting audio?....I would suspect the LVDS Cable needs cleaning and re-seating or the T-Con Board failure.
    • Nightwalker
      • Oct 2012
      • 76
      • Greece
      Hello Andrew F. Ali
      Audio working, i have already check LVDS cable, TCON at the bottom side of metal frame after visual inspection seems ok.
      Also i forgot to upload schematic..i suspect IC4120, page 36 at the middle.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You would need to verify the T-Con is getting power. Look for a fuse on the T-Con Bd. Note: Screw the T-Con Bd down before applying power.
        • Nightwalker
          • Oct 2012
          • 76
          • Greece
          Sorry, my mistake here for not explain it right, T-Con isn't exist as separate board...is built in on MAIN Board.
          At the bottom side of metal frame is the LVDS cable connection to the Panel..
          IC4150 and IC4120(T-Con DAC and T-Con DCDC IC's) are on the MAIN BOARD
          Also found IC4120 datasheet:
          Code:
          http://www.ti.com/lit/ds/symlink/buf12840.pdf
          • Bazfletch3
            Panasonic TH-65FX800A backlight LED's working but picture is very dark
            by Bazfletch3
            Hi all
            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
            From there I envisaged that the backlighting wasn't working, however...
            01-08-2024, 10:18 PM
          • renech
            panasonic TH-42PC77U plasma television half screen problem
            by renech
            hello,
            I hope someone on this forum can assist me.
            I have a panasonic TH-42PC77U plasma television.
            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
            I have read some posts that suggest the problem is related to the boards on the left...
            12-12-2022, 06:53 PM
          • doorzon
            AOC AGON AG273QCG refresh problem picture shifts
            by doorzon
            hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
            The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
            See attached picture.
            I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
            However, this could also be related...
            08-12-2023, 02:36 AM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
