toshiba 40 inch lcd tv with lines and screen fickers
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    hi...need your help
    toshiba 40 inch lcd tv..
    sold a main board on ebay from a tv with cracked screen....tv worked fine other than cracked screen...no other issues...
    the buyer says board no good....he said his tv still has lines across screen and flickers
    since i know my main board works i know his issue is not a main issue......well im pretty confident....nothing is ever 100%
    what do you think?.....all input would be appreciated...i get tired of buyers on ebay that buy wrong boards and then want refunds inclduing shipping back.....it sucks
    thanks
  • shelby5041
    • Feb 2009
    • 1504
    Re: toshiba 40 inch lcd tv with lines and screen fickers
    my tv did not have lines or flicker....it just had a cracked screen......the board i sold him came from my tv
      You should ask for the screen shot of the image on the screen.
      People on EBAY use people like you and I for the board swapping troubleshooting, it is one reason we do not sell boards on EBAY any more, sick and tired of dealing with DIY that really do not know what they are doing.
      • shelby5041
        • Feb 2009
        • 1504
        i asked him to send me a pic....we will see if he will
        but from what i said.....could it be a main board?....i know my main worked so.....
        to me it sounds like bad lcd panel / connections
        what do u think
        • shelby5041
          • Feb 2009
          • 1504
          you fix a lot of tvs....so what would be first thing to check with lines and screen flcikering?
          • shelby5041
            • Feb 2009
            • 1504
            im afraid hes going to proicess an ebay claim...so i need to provide ebay with hard data so i have a good chance to not let this guy screw me out of $100.00 + and
              If he has a couple solid Vertical or Horizontal bars, main board cannot be doing that.
              Flcikering: Bcklightights flcker, that can be due to bad dim command signal. Bad T-CON is causing the images flicker?
              • shelby5041
                • Feb 2009
                • 1504
                yeah and ebay protects buyers.......and screws sellers.......we cant even leave neg feedback,......but buyers can......its sad
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 7986
                  stop dealing with e-bay then? I closed off my ebay account long time ago.
                  • shelby5041
                    • Feb 2009
                    • 1504
                    what other option do i have for selling parts....?
                    ebay is a great place to sell but have to deal with ebay idiotic rules....
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I just saw one TV repair company make short 1 minute youtube videos showing the board in a full TV working on video and they clearly mark the board with a marker. So presumably, if you are buying a working board, they link the youtube video with the unique marking.
                      That way, the buyer can't say they got a non working board?
                      --- begin sig file ---
                      --- end sig file ---
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 7986
                        maybe here? https://www.badcaps.net/forum/forumdisplay.php?f=12
                        • Stanley1843
                          Screen Display Vertical Multicolor Lines
                          by Stanley1843
                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                          06-29-2024, 11:54 AM
                        • jeyoung12
                          Samsung QN50Q60t lines on screen
                          by jeyoung12
                          Hi all
                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                          So....i don't know what end of the C ribbon to work with...
                          02-26-2024, 10:38 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                          09-06-2024, 05:27 AM
                        • kdaniel
                          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                          by kdaniel
                          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                          Left...
                          11-16-2022, 09:23 AM
