I am getting O Volts out of this. By the looks of the schematic, my voltages are not what they should be. I will try to upload schematic.
Standby Transformer Voltage
Tags: None
Re: Standby Transformer Voltage
Checked mains fuse any voltage on primary caps ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/ -
When you have dead switching power supply you will need to check:
1) Main AC feeding the board.
2) Main AC fuse.
3) Ac getting to the rectifiers to convert AC to feed main filter cap.
4) DCV between the two legs of the main filter cap, for 120VAC Line you should have 165~170VDC, for 230V AC line,you should have about 325~330VDC.
If all of the above are OK, then you need to trace the B+ connection of the main filter cap to see if it goes to any fuse or fusible resistor to feed the STBY SMPS section.
You need to have at least the MAIN DC first. If all are present then you dig deeper in the STBY SMPS section.Last edited by budm; 09-05-2015, 10:59 AM.Never stop learning
Hi
I have a desktop power supply unit (SMPS) which is not working and completely dead. I have tested this power supply by connecting ground to green wire but this power supply fails to turn on. There is no +5v standby voltage. On visual inspection there is no sign of any burnt component, blown fuse, short circuit or bad capacitor (like a swollen top or a leak in capacitor).
I have examined this power supply using a multimeter. There is a 230V AC on PCB track pad where AC input wires are connected. The fuse is working and intact. when I connect this unit to AC the first transformer, thyristor, bridge rectifier, and two big capacitors of Filter circuit all are working properly and there is approx. 170v DC on each of the capacitor.
I have also tested three NPN power transistors from the switching section (by removing them from PCB and testing them separately) which are working properly. I have no idea about the PWM switching IC SDC7500 and I have not tested it yet.
There is a key problem that i have diagnosed is that there is no voltage on the two legs of SM transformer Primary side and the Secondary side have seven legs and all of them shows full continuity, which I doubt is wrong but even after removing the transformer from PCB there is 0v on the primary side of the PCB tracks.
I need some help to diagnose the unit and locate the faulty component. Could someone please help me and tell me some more test points to test this unit.
Thanks and Regards
Bucephalus
In these images i have removed three transistors and the heat sink for testing purpose only.
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Image 7
Image 8Comment
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
Assuming...7 Photos -
by Bad_IC
I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
These are the voltages in some pins of IC fsq510:
Vcc=18v
D=320v
Vstr=154v
Unfortunately, I couldn't find the schematic
What else could I check?
Is it possible to provide standby voltage from an external source to allow the TV to turn on?
Thank you​... -
by UserXPHello, people.
i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone... -
by brock-sAn Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically... - Loading...
