Philips 46pfl5505d/f7
  • CapLeaker
    Leaking Member
    • 8326
    Re: Philips 46pfl5505d/f7
    delete double post.
    • CapLeaker
      Leaking Member
      • 8326
      Funny... third try to post.
      So what it looks like the BL-sw pin 14 coming from the main board is intermittent, or not there most of the time. The LED blinking 21 times is probably a backlight error. I think your PSU is fine. So what to do next to disconnect only BL-sw pin 14 that goes between the PSU and the main board and force it on manually with a resistor.
      • krygods
        • 257
        1k ohm resistor from CN2 Pin 9 to Pin 14?
        • CapLeaker
          Leaking Member
          • 8326
          yes
          • krygods
            • 257
            Ok I jumped Pin 9 to Pin 14 with 1k resistor.
            Backlight comes on, standby light blinks 21 times, during the pause between 21 blinks the backlight turns off and then turns back on when the 21 blinks starts over.
            • CapLeaker
              Leaking Member
              • 8326
              When there is a pause during the 21 time blinking LED, does PSon go low in voltage?
              • krygods
                • 257
                Yes PSon goes from 3.1VDC to zero and then back to 3.1VDC
                • CapLeaker
                  Leaking Member
                  • 8326
                  5v stby rock solid during this?
                  • krygods
                    • 257
                    Rock solid at 5.4VDC
                    • CapLeaker
                      Leaking Member
                      • 8326
                      main board problem
                      • krygods
                        • 257
                        possible to troubleshoot or just find a replacement?
                        • CapLeaker
                          Leaking Member
                          • 8326
                          What is your mainboard? Maybe upload some hi res, straight shot pics. That stuff is small and we have to trace. Got to find the standby processor with the BLon pin and see what is what... not an easy thing. That feeds of course from the 5V STBY and it being blown, it probably done something somewhere to it. There is also the STBY processor EEPROM, that could prevent the TV to turn on proper.
                          So, if you find a working main board for cheap, that's your best option right now.
                          • krygods
                            • 257
                            Well, I've looked online for main boards are there aren't any at all for sale. I'll keep an eye out in the meantime, but if you don't mind helping with troubleshooting I'll get out the tripod and DSLR and take some Hi-Res pics of the front and back of the board.
                            • CapLeaker
                              Leaking Member
                              • 8326
                              sounds like a plan
                              I hope someone has maybe a schematic for the PL10.7 chassis main board?
                              • krygods
                                • 257
                                Here are front and back shots for the time being. As soon as the DSLR is done charging I'll get some Hi-Res pics of the front and back.
                                I believe this is a link to the service manual if I'm not mistaken.
                                http://www.manualslib.com/products/P...7-1477495.html
                                • CapLeaker
                                  Leaking Member
                                  • 8326
                                  Yeah... unfortunately I can't read it. Too small
                                  On pic 1 the lower left corner, that should be the plug for the PSU. Can you make another pic of that section?
                                  Also with pin is the BLon pin on there?
                                  • krygods
                                    • 257
                                    Here are some pics of the front side with DSLR camera.
                                    I think the images are being re-scaled after I upload them. The original files are 4MB and now under 1MB after uploading. Hope it doesn't affect legibility.
                                    • krygods
                                      • 257
                                      Back side of main board
                                      • krygods
                                        • 257
                                        BLsw is Pin 1 of CN3002
                                        • CapLeaker
                                          Leaking Member
                                          • 8326
                                          Got another idea for you to test. Put the boards back into the TV everything as it supposed to be... no forcing things on the PSU. Heat up the main board with a hair dryer. Don't overheat it though... then turn on the tv. See what it does.
                                          If you didn't get any results, try cooling specific regions the main board (can of duster air upside down) and see if you can find something that way.
                                          I partially traced the BLon pin, but I lost it... (reminds me I should get a bigger screen here).
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • ivtec
                                            Philips 46PFL5505D/F7 thin green line?
                                            by ivtec
                                            Hi guys i have this Philips 46PFL5505D/F7 that has a thin green line in the corner almost unnoticeable ,this probably has been here for a long time,and it more noticeable when watching regular tv entertainment,since i mostly watch soccer on this tv because of the green field ,it's probably i never noticed it ,do you guys think this might be the ribon cables , tcon board or main board ?...
                                            12-24-2020, 12:57 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
