Philips 46pfl5505d/f7
  • krygods
    • 257
    Philips 46pfl5505d/f7 no power / standby light.
    I've desoldered all the caps and transistors to test and they all tested good.
    The discoloration on the back side of the board is from desoldering not leaky caps.
    Wondering what the next step would be in troubleshooting the power supply?
    Any help, suggestions, or opinions would be greatly appreciated.
    Re: Philips 46pfl5505d/f7
    Do you get 5.3V DCV at the conector CN2 pin 9? You did check main fuse?
    Do you get 160~170VDC between the two legs of those two main filter caps in the primary side of the circuit?
    http://www.shopjimmy.com/philips-upb...nit-board.htm#
    • krygods
      • 257
      The main fuse tested good and I've checked for AC voltage on both sides.
      There is no power at Pin 9 of CN2
      The two filter caps are the two largest ones under the largest piece of shielding in the lower center portion of the board?? C800 and C808 - 150uF 400v?
      • krygods
        • 257
        I tested the two caps I mention in the previous post.
        Both show 160-170VDC
        • krygods
          • 257
          What would be the next thing to check after making sure those two caps have voltage?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            There's a service manual which looks as though it has the power supply at:
            http://tinyurl.com/o9jdbkh
              So you do have main DC to run the STBY power supply section.
              You board is Delta model DPS-360GP.
              We do not have the diagram for the board so we will have to trace out the circuit manually.
              So how much times and patients do you have to troubleshoot down to component level?
              The STBY section has IC901 for the SMPS, Power transformer T901, startup/running caps c906, the other cap is cover by the white glue so I cannot tell what that C is.
              Disconnect the cable to that connector which goes to the main board to see if the 5V will be present, if not then unplug the AC thenyou can try heating those two caps with hair dryer for a few minutes and then reapply the power to see if the 5V will be present.
              We will also need the P/N as printed on top of the IC901.
              Thanks for the diagram DICKBARTON.
              See if the P/N matches the IC901.
              Pictures provided by SHOPJIMMY.
              • krygods
                • 257
                IC901 - DNP005 G0923
                The capacitor number covered by the white glue is C912
                Let me go ahead and do as suggested above and I'll post back with the results.
                • krygods
                  • 257
                  Didn't see any voltage at Pin 9 with the main board unplugged.
                  Tried heating caps C912 and C906 with hair dryer and testing still no voltage at Pin 9
                  • CapLeaker
                    Leaking Member
                    • 8155
                    check if ZD951 is shorted
                      OK, looking at the diagram, let make sure th Zener diode ZD951 on the secondary side is not shorted out, use Ohm mode to check the resistance between the two legs of the the Zenner.
                      Also need to check D906, 908, 909, and ZD904 in the primary side.
                      • krygods
                        • 257
                        I'm unsure if I'm testing the diodes correctly so I took pictures of each diode while I tested them.
                        • krygods
                          • 257
                          Last two diodes
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            D906 is OK, ZD908 is OK, D903 is OK, D909 is OK
                            D950, D951 and ZD951 show as shorted, possibly they are in parallel so maybe only one of them is bad.
                            Your meter needs a new battery too.
                            -David VanHorn
                            • krygods
                              • 257
                              Okay, let me go ahead and remove D950 and D951 so that I can test them and then I can also test ZD951 while still on the board because that one is a PITA to desolder.
                                D950 is connected in parallel with D951, the Zener ZD951 (1N5920, 6.2V 1.5W) is for clamping the output of the D950/951.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  Desoldering ZD951 shouldn't be too hard, just make sure you are desoldering the diode from the turret terminals and not trying to remove the turrets from the board, which are probably crimped on as well as soldered.
                                  EDIT: after a better look at the photo, perhaps the diode is crimped into the turrets. I can't see any solder there. Strange!
                                  -David VanHorn
                                    You just need to lift one end off the board.
                                    • krygods
                                      • 257
                                      This is D951
                                      • krygods
                                        • 257
                                        ZD951 and D950
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • ivtec
                                          Philips 46PFL5505D/F7 thin green line?
                                          by ivtec
                                          Hi guys i have this Philips 46PFL5505D/F7 that has a thin green line in the corner almost unnoticeable ,this probably has been here for a long time,and it more noticeable when watching regular tv entertainment,since i mostly watch soccer on this tv because of the green field ,it's probably i never noticed it ,do you guys think this might be the ribon cables , tcon board or main board ?...
                                          12-24-2020, 12:57 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
                                        • spantor
                                          Activate power board Philips 40PFH40009/88 tv
                                          by spantor
                                          Hello partners.
                                          Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                          The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                          02-11-2024, 05:07 PM
