vizio plasma help? p50hdm
  • mattstolte
    • Dec 2013
    • 612
    • usa
    got this model and am trying to figure out what is going on. im thinking ysus?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: vizio plasma help? p50hdm
    Anybody please
    • nicholas1110
      • Aug 2012
      • 127
      • usa
      This is a very common buffer fault on these model. There is mosfets that short on the buffer board. If you search this forum you will find many others with the same fault.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        You talking about the buffer boards connected to the ysus?
        • mattstolte
          • Dec 2013
          • 612
          • usa
          I checked the buffers they seem fine
          • aaronwt6
            • Apr 2013
            • 855
            • US
            I second the buffer opinion. And from the picture and personal experience, I'm guessing on the lower buffer. Double check the fets on that one. All three will show shorted because they are connected in parallel. You'll have to lift a leg on each to figure out which one it is.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              You can also try disconnecting the jumper between the two buffers to start. Power up the TV with only the upper connected. If the lower is bad, you should get a picture on the top half of the screen.
                It is definitely a buffer fault and usually pretty easy to fix by replacing those six surface mounted FETs on the buffer board.
                But don't delay as leaving it like this can eventually kill the IPM which is NOT an easy fix.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  tom can you show me how to test them i followed another link on coppeal tv repair blog on how to test the buffer boards and they seemed fine tested 2 ways
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • PlasMatt
                    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                    by PlasMatt
                    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                    09-20-2025, 06:50 PM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
