Hello all.
Been having pretty good luck with LCD's and such, so I did manage to nip up a cheap plasma for repair. (I know, glutton for punishment)
It's a Sanyo DP42740 Chassis: P42740-05
Please let me know what, if any picture would be needed and I'll follow suit. However all the capacitors seem to be in extremely good condition. The set itself has a build date of 2012.
Woman I picked it up from described the initial issue: No picture, has sound. She then put it into a storage bin until she found my advert. The storage bin appears to have had a water leak, as there is very minor water 'crust' on the lower right of the inner frame. While it looks like it should be an issue? I do not feel that is the cause of the problems. (Trying to avoid the expected knee jerk reactions)
Here's what the set does:
Plug the set in--you hear 3 relay clicks. Two 'rapid' and one more at a slight delay. The two clicks are the power supply main relays. The 3rd click seems to be the upper relay clicking an additional time-likely shutting 'off'. There is a green LED on the buffer board--It reminds me of a fluorescent bulb starting up. A touch 'dim' for a second kinda flickers. Then snaps on at a normal brightness. Upon examine of the screen itself we have a very noticeable "Glow" with the entire screen. So that tells me that the plasma boards themselves are getting juice and the screen is waiting for a picture input. (That's also how I know that dry crust at the lower right side isn't having an effect on the screen--it's not blown/blowing any fuses and the voltages seem to be okay as far as I can tell)
It almost seems like the set is turning the plasma screen 'on' and then not turning on anything else. As we have no action otherwise. I can press the buttons on the control panel and it's also dead.
I did notice a repair kit that shows for chassis ending in 04. This one appears to have the same double-connected tuner/main board. The repair kit is made to solve the issue of it cycle clicking on/off and audio issues. We sorta have a clicking thing going on, but it's not clicking on/off every few seconds as the service info seems to state that cures.
Wondering if anyone has run into this problem before. I can of course supply photos as requested. In order to get a better set of numbers for voltages, does anyone have a pinout of the PSB? It looks like I have the correct voltages, but it's got a PITA "Darfon" with limited information for a power board.
S-
S-
