Toshiba 32w3453d no video or audio backlight on
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #61
    Re: Toshiba 32w3453d no video or audio backlight on
    Ok have you checked for voltage and S/C on that pcb ?
      09-06-2024, 05:27 AM
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • SolarFlare
      Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
      by SolarFlare
      My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
      The TCON board has the following Chips -
      Samsung VTU63A0
      RT6939 - 2nos.
      and all these chips are getting real hot within a minute, I dont know if this is normal....
      06-26-2022, 08:58 AM
    • Max514
      Samsung UN55H8000 sound but no backlight no video
      by Max514
      Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
      The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
      I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
      • Unplugging the main board cable at the power supply >>> backlights came on.
      • BLU_ON signal from the
      04-14-2022, 10:34 AM
      Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
      This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
