Toshiba 32w3453d no video or audio backlight on
  • vinceroger69
    • Mar 2012
    • 6714
    #41
    Re: Toshiba 32w3453d no video or audio backlight on
    Originally posted by london-freddie
    no tcon board
    sorry i re edited my post ive just looked at your pictures again.
    • london-freddie
      • May 2015
      • 472
      yes replacement mainboard has all same numbers on stickers and came from a set with same panel number, as far as i can see nothing is going through the mainboard in either direction
      • london-freddie
        • May 2015
        • 472
        just emailed the seller whom i got the replacement mainboard from to see if he has another, fingers crossed
        • vinceroger69
          • Mar 2012
          • 6714
          #44
          yes thats what i would do in your situation or get a refund and try a diffrent seller
          • london-freddie
            • May 2015
            • 472
            seller not got another board now to try and find another board
            • london-freddie
              • May 2015
              • 472
              found another board today, ordered it and its on its way to me
              • london-freddie
                • May 2015
                • 472
                OK replacement mainboard arrived today, fitted it same result, red power light flashes and changes to green, backlight comes on NO Sound or Picture
                Have now changed the power board and this is the second replacement mainboard, still the same as when I first got this set
                • london-freddie
                  • May 2015
                  • 472
                  Not happy and cant let this set beat me now
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #49
                    Probably means that the lcd screen is fucked and something on it is shorted try taking the bezel off and see if there are any obvious exploded parts on the tab section of the lcd. Also maybe you do have sound but not on the correct input.
                    • london-freddie
                      • May 2015
                      • 472
                      OK got this tv apart again, put a mp4 film on a usb stick in usb slot, audio is now there, so I do have audio but I still have no picture, just the backlight
                      Connected via HDMI and Scart cables to a working tv no picture is displayed on the working TV, so I may be wrong but that is now telling me that there is no video output from the mainboard.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #51
                        But you replaced the mobo twice ?
                        • london-freddie
                          • May 2015
                          • 472
                          yes have replaced it twice, I have now got its original mainboard in the set that was in when I got the tv.
                          I am now sat listening to the sound from iron man film but no picture on the screen, and no video being sent out via scart or hdmi, I am stuck on this but am convinced it is a mainboard fault. \just a thought of mine maybe the mainboard in the set is not the correct mainboard, I do not know if it had been changed before I got this set, I have replaced the board with the same number as what is fitted now, however, looking on the web there are several different mainboards for sale for this model of tv with different part numbers. If that makes any sense to you
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4978
                            • New Zealand
                            #53
                            Does SCART\HDMI output work if you disconnect the panel?
                            -David VanHorn
                            • london-freddie
                              • May 2015
                              • 472
                              think I tried disconnecting the ribbon and still no scart output but will try again next week, am away now for the weekend
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                maybe also if you havnt look for any burnt parts on the panel board there may even be a fuse on it i havnt really looked on these boards before.
                                • london-freddie
                                  • May 2015
                                  • 472
                                  no sign of any damage, surface mount fuse next to connector is ok seem to have 12v in several places on this board
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    What about on the panel on its tab/pcb section ?
                                    • london-freddie
                                      • May 2015
                                      • 472
                                      panel board
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #59
                                        Wow that really is a piece of shit one tab to drive a 32" 720p glass. Right try pressing on the tab bond and ic and see if image comes back ?
                                        • london-freddie
                                          • May 2015
                                          • 472
                                          tried that no change at all
                                            09-06-2024, 05:27 AM
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • SolarFlare
                                            Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                            by SolarFlare
                                            My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                            The TCON board has the following Chips -
                                            Samsung VTU63A0
                                            RT6939 - 2nos.
                                            and all these chips are getting real hot within a minute, I dont know if this is normal....
                                            06-26-2022, 08:58 AM
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                            Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
