Sharp LC-70LE757U Flashing 2-5 :-( can it be saved economically?
  • sleepingAwake
    • Jan 2014
    • 10
    Re: Sharp LC-70LE757U Flashing 2-5 :-( can it be saved economically?
    Wow. Well I let you guys know how I make out when I get another TCON.
    I think my tv has an issue with the left side drivers though.
    Gotta be sure. Only get one chance!
    • freakaftr8
      • Oct 2012
      • 3743
      Looks good! Congrats
      • budwich
        • Jul 2015
        • 3097
        Just as further follow up. TV has been moved back to the neighbor (owner). He decided to return the replacement samsung (still within the return period... that's another discussion, not to my agreement) and is now using the "saved" sharp. Not sure how long it will go but will report if anything shows up.
        • tucocaps
          • Apr 2013
          • 331
          • United Stated
          #124
          So it was still a "panel problem" , but one you were able to sort of fix. Wow. Way to go. Kinda wish I had known about this before, but I'm pretty sure all of mine were cracked anyway.
          • freakaftr8
            • Oct 2012
            • 3743
            And I'm also happy to report that the 70 inch vizio e701i-a3 that I repaired with the same problem of course using a sharp panel is still working fine used heavily everyday
            • Golgo13
              • Oct 2015
              • 10
              • US
              #126
              Any updates on the TV? I have the same model and I'm about to tackle this same task. Hopefully HOPEFULLY I'll end up with the same result. It's such a shame too, I've had the TV less than 2 years and already it's down for the count.
              • budwich
                • Jul 2015
                • 3097
                Neighbor took back his samsung and moved the "saved set" back into its rightful spot. He says the picture is as good as the day he bought... :-) Its been operating most evenings and weekends for about 10 days now. Anyways, he is kind of ahead of the game as Sharp originally gave him some "compensation" for the panel even though it was out of warranty and let him keep the set "for parts". You should perhaps contact sharp first to see if they will do anything for you before you embark on this journey.
                • Golgo13
                  • Oct 2015
                  • 10
                  • US
                  #128
                  Yeah I think I'll do that. I have my receipt and everything. It's a week shy of being two years old and for the amount of money I paid that's a shame. Hopefully sharp will identify this problem and update the design. Thanks so much for not quitting and following through with the save. My heart sank when I got the 2-5 morse code and every place I read said it wasn't possible to save it. I have already learned so much from this thread, gives me hope lol.
                  • Golgo13
                    • Oct 2015
                    • 10
                    • US
                    #129
                    There is one concern though...I have the LED model lc70le7500u so I wonder how much this is going to differ from the LCD one your repaired
                    • budwich
                      • Jul 2015
                      • 3097
                      I think if you follow the thread here and others that have been posted, various TV models present themselves with different issues. There is no guaranty that the "fix" mentioned herein will work on your set, first because you need to identify the EXACT issue and second, you need to test where the fault may lie. Pulling / removing the flex tab /driver cables IS the LAST resort and NOT the starting point in your journey.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #131
                        Some credit cards double the original manufacturers warranty. Check yours if you paid by credit card.
                        --- begin sig file ---
                        --- end sig file ---
                        • Golgo13
                          • Oct 2015
                          • 10
                          • US
                          #132
                          So I haven't had time to delve into this as I've been on a 3 day out and back with the military. Anywho, I come home and had left the TV unplugged the whole time I was gone. Just as a hey what the hell, I plugged it in and everything worked as advertised...something is fishy here....I know it's only a matter of time before this sucker acts up again. Now I've got to decide if I want to open up this can of worms or not....I doubt the LED TV fairy came and fixed it while I was gone. Hmmmmmm
                          • Golgo13
                            • Oct 2015
                            • 10
                            • US
                            #133
                            Checked the receipt and of course I paid in cash....but thanks for that tip! From now on I'm going to keep that in the back of my mind and call my credit card company tomorrow and see if they honor such a thing. Appreciate the help!
                            • budwich
                              • Jul 2015
                              • 3097
                              Hope the "TV fairy"'s magic holds. Likely, scenario is that in "standby" and regular usage, that some heating is causing a problem somewhere but hopefully its not catastrophic. Good luck
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                I would be more susceptible to thinking that you have a tcon problem instead of a panel problem. Usually panel problems rear their ugly head right away tcon sometimes take a while under normal operating temperature.
                                • Golgo13
                                  • Oct 2015
                                  • 10
                                  • US
                                  #136
                                  I was thinking that exact thing. However, earlier on in the thread where budwich was toying around with the different ribbons cables on the tcon board and only getting to connect 3 out of the four before the 2-5 cycle, that same thing happened to me.
                                  Last night I dove into it and ended up only being able to have three ribbon cables on the tcon, as soon as I connect the furthest left, 2-5 cycle. In fact, I can disconnect that, turn it on, (tv does in fact come on) then carefully reconnect it and she's good to go. After I get it working correctly, with all tcon ribbon cables connected, I can turn it off and on with the power button. It's only when I wait roughly 10-12 seconds with no power on and then try and turn it on again that it goes back into the 2-5 cycle. At that point I have to disconnect the furthest left cable and start the process all over again. That ribbon cable I believe is an 80 pin and goes to what I'm guessing the drivers for the panel?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    Actually, my set acted exactly the same way. When I found that I could carefully connect the 4th cable and get the set "up", it ran for about 20 minutes then shut down. When I tried a couple of more times, I found the "thing" about sequence for starting (ie. connecting the 4th cable) and then could turn it on and off quickly (5-10 seconds), it would start up OK. Longer than that and it would only code flash thereafter. Eventually, I couldn't get into the "start up mode" with 4 cables connected and that's when I moved on to other cables "removals" looking to isolate which section was "complaining".... eventually ending up at the lower right side ribbon cable.
                                    • Golgo13
                                      • Oct 2015
                                      • 10
                                      • US
                                      #138
                                      Well folks it's come down to this, I can get her to crank up about one in ten times plugging it in. Come Monday my buddy is going to help me wrestle this monster back off the wall but until then I'll just keep pickin away at it via the outlet. Once again thanks all for the help. Awesome forum. I'll let you know what I find once I can get the bezel off.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        What exactly are you seeing on the screen when it's up and running? Any odd horizontal lines or picture issues of any sort representing a failed side tab driver?
                                        • Golgo13
                                          • Oct 2015
                                          • 10
                                          • US
                                          #140
                                          Well, when I can get it to boot up, the picture is absolutely flawless! At one point in time I did have the horizontal flicker but it was just briefly so I just turned the tv off and turned it back on. Never happened again. Then one day, it wouldn't turn on at all. I can't get it up and running with the input vol down button trick so that's out. But repeatedly turning off and on does work, just takes a while.
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • dmcabs
                                            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                                            by dmcabs
                                            Hey guys,
                                            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                                            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                                            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                                            I'm a bit rusty but still have ability to dig right down.
                                            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                                            09-21-2024, 11:09 AM
                                          • JunkmanJimbo
                                            sharp lc-65ub30u plays but screen is flashing on and off
                                            by JunkmanJimbo
                                            Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                            09-07-2024, 09:45 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • DrvLikHell
                                            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                            by DrvLikHell
                                            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                            The...
                                            02-05-2025, 01:44 AM
