Samsung LE40A556P1FXXC (T-Con V400H1-C01) solarized image
  • fearnaboinne
    • Aug 2015
    • 4
    • The Netherlands
    I have a Samsung TV (as above) with solarized image (See attached image)
    I measured the test points (TV on, no inputs connected) on the T Con board (V400H1-C01), which sports an AS19-H1G, and they measure (from 1 - 17) as follows:
    13,13V
    11,67V
    11,04V
    10,46V <-- !
    10,96V <-- !
    10,56V
    9,96V
    7,69V
    7,03V
    6,46V
    5,93V
    4,47V
    4,01V
    3,64V
    3,48V
    4,53V <-- !
    2,05V
    Am I correct in diagnosing that the T Con has died, and specifically the AS19-H1G chip?
  • flocko
    • Nov 2012
    • 1121
    Re: Samsung LE40A556P1FXXC (T-Con V400H1-C01) solarized image
    Yes these test results show the AS19 IC to have failed. the problem with this is the ICs are very hard to remove from the board without doing damage. As the back of the IC is bonded to T-Con board and no amount of heat seems to help.
    • fearnaboinne
      • Aug 2015
      • 4
      • The Netherlands
      Thanks for the confirmation... I've read about the 'challenges' these chips pose... Best I can do - I guess - is try to remove it, and see what happens... If it comes off, great, if not, I won't be off any worse, and will need to order a replacement board...
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        My advice is just go ahead and get a new T-CON replacement. Those AS15/19 chips are really difficult to replace unless you have the proper tools and correct procedure. I 've failed miserably at doing this job. Less headache is what I mean.
        • mmartell
          • Oct 2013
          • 3189
          I've been trying to lift one of these recently without luck but have not destroyed the board yet either. How is this ic "bonded" other than with the ground pad ?
          My replacement AS19 is arriving tomorrow and I was about to let the big dog eat (paint stripper), maybe not such a good idea...
          Someone else me tioned dremmeling down the ic - might be the way to go.
          Anyone with knowledge on how the as19 is affixed to the board ?
          • flocko
            • Nov 2012
            • 1121
            The AS19-HIF is the larger 5.0x5.0mm IC and has an exposed pad that is soldered to the board, the AS19-HF is the smaller 3.5x3.5mm IC but also has the solder pad . to remove you need a good hot air station and lots of good quality no clean flux, pre heat the back of the board ,then using a small nozzle play the hot air on the centre of the IC, the heat will generate to the pad and pins. you should not need to heat to long before it will lift off don't force it, if it wont lift kept heating till it will
            • mmartell
              • Oct 2013
              • 3189
              I have the AS19-H1G, anything to note about that one ? Will try your suggestion.
              • flocko
                • Nov 2012
                • 1121
                AS19-HIF = lead free
                AS19-HIG= green mode ? Just for production line soldering and makes them hard to get off
                • mmartell
                  • Oct 2013
                  • 3189
                  I will still attempt to heat the center of the ic and will report back.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Got it off but tore one of the corner pads off. Also when I first lifted it things didn't look quite right so I heated again and off came a "plate" that doesn't appear to be part of the ic. Didn't reinstall it.
                    Lost a couple resistors in the process so this is now in resurrection mode. I didn't write down the locations but will do so soon, maybe someone has one of these laying around that they can lift some measurements from.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
