Sansui Sled2453w No Standby Set Is Dead
  • Sinfury2112
    • Jul 2014
    • 71
    Re: Sansui Sled2453w No Standby Set Is Dead
    tried replacing the 50v 22uf no change
    • jetadm123
      • 2169
      What's the part number of the 8-legged chip connected to the startup cap that you just replaced?
      • Sinfury2112
        • Jul 2014
        • 71
        Originally posted by jetadm123
        what's the part number of the 8-legged chip connected to the startup cap that you just replaced?
        6c12105
        5640
        • Sinfury2112
          • Jul 2014
          • 71
          I need service manual
          • CapLeaker
            Leaking Member
            • 8146
            Check that thermistor
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #26
              If the 5640 is an FA5640 then the pdf file is available from:-
              Vcc on pin 6 should be a min 11V, typ 14v, max 26V
              • Sinfury2112
                • Jul 2014
                • 71
                thermistor says 4.7 1136 on it im assuming its 4.7 ohm it tested 5 or 6 ohm cold and dosent drop much when I wave heat around it with my solder iron is that good?
                also theres 9.7v on pin 6 of the 5640
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  Try heating the powerboard up nwith a hair dryer for about three to four minutes some times if its a bad capacitor this can get the supply tempory working also 9.7 volts on pin 6 seems low its 11 volt minimum according to the pdf
                  • Sinfury2112
                    • Jul 2014
                    • 71
                    I heated the board like you said not much change at all 9.7 to 9.8 give and take
                    • Sinfury2112
                      • Jul 2014
                      • 71
                      could I add a few volts to see if it will fire up would that be safe?
                      • CapLeaker
                        Leaking Member
                        • 8146
                        Hell NOT! Working on the primary is a dangerous thing as you are connected to the mains!
                          Did you replace the blown 0.22 Ohms resistor R510 with the jumper wire? Looking at your pictures and the board layout, that's what it looks like to me.
                          That is the fusible resistor for the Main B+ to feed the SMPS section, that blown resistor will not cause you to lose 170VDC on the main filter cap.
                          There must have been a shorted circuit to take out that fusible resistor and the shorts circuit could have blown open circuit otherwise it will blow the main AC fuse if the shorts is still present.
                          So for sure you are getting 170VDC between the two legs of the main filter cap?
                          "Fuse is good I found a blown 0.22 ohm resistor replaced that now have 170v across main cap"
                          This statement does not make sense at all since the resistor is connected to the + leg of the cap, and the other leg of the resistor is fed to the SMPS section.
                          That fusible is blown for a reason.
                          • Sinfury2112
                            • Jul 2014
                            • 71
                            yes that is a jumper wire I added the fuse never blew and I do get 170v across the main cap
                              Check R505 (Source resistor for the MOSFET), it should be <1 Ohms.
                              Also take the resistance readings of all the pin against the GND pin of the SMPS IC FA5640 and report the readings.
                              • Sinfury2112
                                • Jul 2014
                                • 71
                                its 055.8k
                                • Sinfury2112
                                  • Jul 2014
                                  • 71
                                  1 = 23.74k
                                  2 = 150k
                                  3 = 057.0k
                                  4 = gnd
                                  5 = 088.8k
                                  6 = jumping all over the place
                                  7 = 0.L
                                  8 = 39.69m and climbing
                                    "could I add a few volts to see if it will fire up would that be safe?" The VCC pin 6 is fed by the internal charge pump circuit which through VH pin 8 which gets the High B+ Voltage through the resistors R501, R512, when the charge pump circuit charges up the Startup/running cap connected to the VCC pin till it reaches the minimum startup Voltage, when that Voltage is reached the IC will send the drive Voltage to drive the Gate of the power MOSFET which then the MOSFET willl drive the power transformer, tho provide the output Voltage on the secondary side winding, at the same time the Aux winding of the transformer will provide the running Voltage to keep the SMPS IC running, the charge pump circuit is then shutdown.
                                    So right now you may have bad Voltage at pin 8, bad charge pump circuit, internal leakage on VCC pin that not allow the VCC to reach the required start up Voltage, bad startup/running cap.
                                      Originally posted by Sinfury2112
                                      its 055.8k
                                      That is blown as I expected, That is the source resistor for that MOSFET Q501, for that resistor to blow up, the MOSFET must have conducted (or shorted out)heavily to take out the fusible resistor and the Source pin resistor, R505 looks to be 0.22 Ohms 1W 5% MOX type.
                                      At this point I would replace both resistors with the correct one not with the jumper, and replace the IC and also the MOSFET Q501.
                                      You also need to check the Gate drive R/D (Resistor-Diode) network which is connected between the drive pin of the IC and the GATE pin of the MOSFET.
                                      • Sinfury2112
                                        • Jul 2014
                                        • 71
                                        the 8 pin ic is the one needs replaced?
                                          Yes,the IC FA5640, the MOSFET, RESISTORS, ...
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • jacobtc
                                            LG C1 65'' dead standby
                                            by jacobtc
                                            I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                            If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                            If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                            I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                            01-29-2025, 04:27 AM
                                          • piposarcade
                                            by piposarcade
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                            01-04-2024, 12:03 PM
