Sansui Sled2453w No Standby Set Is Dead
  • Sinfury2112
    • Jul 2014
    • 71
    Trying to fix this set for friend of mine there is no standby light at all he said heard pop and quit working. Fuse is good I found a blown 0.22 ohm resistor replaced that now have 170v across main cap he purchased new mainboard from ebay but the prob lies in the psu somewhere cant find schematics anywhere what I think is the startup cap 50v 22uf has 10v across it any help would be much appreciated here is pics of the psu below thanks for looking P.S also tested large diodes and mosfet out of the board tested okay tested all smaller diodes in board tested okay
  • CapLeaker
    Leaking Member
    • 8030
    Re: Sansui Sled2453w No Standby Set Is Dead
    Sorry... you got to make better pics than that. Everything is just a big blurr.
    • Sinfury2112
      • Jul 2014
      • 71
      Here Are Clearer Pictures I Hope This Helps
      • CapLeaker
        Leaking Member
        • 8030
        Not really... those are better, but I still can't read not a thing. Be careful there are lethal voltages in the primary circuit. Plug the PSU in and see what you get on the main filter cap.
        • Sinfury2112
          • Jul 2014
          • 71
          I get 170v on the cap
          • Sinfury2112
            • Jul 2014
            • 71
            sorry about crappy photos I think you can read these now LOL my cam really sucks!!
            • jetadm123
              • 2169
              With power disconnected, try checking large transistor Q501 for a short. Really surprised it's not heat sinked.
              • Sinfury2112
                • Jul 2014
                • 71
                I tested that mosfet out of the board checked good im stumped well my meter has only 1.6v in the diode test mode so I used a 9v battery to charge the mosfet in the on position does it matter?
                • Sinfury2112
                  • Jul 2014
                  • 71
                  I think I just found my problem the opt coupler is wide open both sides
                  2561a is part number
                  • CapLeaker
                    Leaking Member
                    • 8030
                    did you check fuse F501?
                    • Sinfury2112
                      • Jul 2014
                      • 71
                      yep fuse is good thank you
                      • Sinfury2112
                        • Jul 2014
                        • 71
                        it had a resister blown when I first got the set it protected the fuse
                        • CapLeaker
                          Leaking Member
                          • 8030
                          check those black square and blue caps on the primary.
                          • Sinfury2112
                            • Jul 2014
                            • 71
                            there is not any markings on the blue caps if I need to replace them I will try test them best I can I don't have an esr meter
                            • CapLeaker
                              Leaking Member
                              • 8030
                              that long blue cap I mean. you don't need an ESR for those type of caps.
                              • Sinfury2112
                                • Jul 2014
                                • 71
                                on the long blue cap it is reading OL. on all of the Resistance Settings its marked GM 223J 2G S'M08 have no idea what the values are to replace it Im guessing its bad
                                • CapLeaker
                                  Leaking Member
                                  • 8030
                                  That should be a 0.022uF/400V cap. You can't measure a cap like that with your meter in resistance. You have to set your DMM into capacitance (if it has one).
                                  • jetadm123
                                    • 2169
                                    The 10v across the startup cap appears a bit low. It should be connected to the vcc leg of the 8-legged pwm smd chip on bottom of the board. If yes, then try replacing the startup cap and see what happens.
                                    • Sinfury2112
                                      • Jul 2014
                                      • 71
                                      the 223j cap measures 23.60nf on meter in cap mode is this bad? the small startup cap measures 23uf and its a 50v 22uf cap
                                      • CapLeaker
                                        Leaking Member
                                        • 8030
                                        The 223j is good. For the electrolytic one you'd need an esr meter, to make sure, I doubt it's bad, but can change it and see what's happens
                                        • piposarcade
                                          Samsung UN50KU6300 dead no standby led
                                          by piposarcade
                                          01-04-2024, 01:33 PM
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                          05-22-2024, 02:07 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • jacobtc
                                          LG C1 65'' dead standby
                                          by jacobtc
                                          I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                          If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                          If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                          I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                          01-29-2025, 04:27 AM
                                        • piposarcade
                                          by piposarcade
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                          01-04-2024, 12:03 PM
