Samsung PS-42D4S plasma. Has sound, no picture. Please help!
  • scokljat
    • May 2012
    • 275
    • Croatia
    Re: Samsung PS-42D4S plasma. Has sound, no picture. Please help!
    Originally posted by ReeceyBurger123
    Do you have a hair drier you can use it to help diagnose the issue ? ?
    Hair dryer? Never heard of such apparatus ;-) Just kidding. I have a hair dryer and I also have a reflow station. What part exactly do you want me to heat? ...and what do you think we're going to accomplish?
    Thanks,
    S
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ok heat the centre of the Psu where the transformers are. They polly cap (little rectangles) I think are near them any how heat the Psu and see if Vs come up. Sorry for the light handed replies as well in college and have to type fast haha.
      • Maklaud
        • Sep 2015
        • 56
        • Russia
        Who's this for a question?
        • Maklaud
          • Sep 2015
          • 56
          • Russia
          Who was asked this question?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I asked it to Sc to help toruble shoot.
            • scokljat
              • May 2012
              • 275
              • Croatia
              #26
              Originally posted by Maklaud
              Yes measure. Because there can be 290-300V and not 390-400V.
              I did some measurements. I measured DC voltage directly on main rectifiers (BD1 & BD3 - two D15XB60 connected in parallel) and I also measured DC voltage on large filter caps (C5 & C6 330uF/450V connected in parallel). Positive sides of C5 & C6 are also connected directly to B+_PFC. See picture.
              Readings when TV is ON (TV is 220/240V model):
              Rectifiers: 215VDC
              Large filter caps (B+_PFC): 320VDC
              Any ideas? Is it too low?? Is that causing my problem - no Vs? What could be the reason?
              One strange thing is - I get those voltage readings even if TV is in standby (relay is OFF), but it may be because filter caps are charged and I didn't wait enough for them to discharge...
              Thanks,
              S
              • Maklaud
                • Sep 2015
                • 56
                • Russia
                #27
                IC1 13 pin (vcc) Voltag = ?
                • Maklaud
                  • Sep 2015
                  • 56
                  • Russia
                  #28
                  (B+_PFC): 320VDC It is low voltage. When TV is turned on = 400V
                  • scokljat
                    • May 2012
                    • 275
                    • Croatia
                    #29
                    I measured IC1 pin 13 (VCC) to pin 10 (GND_H). I see GND_H is not same as RTN (chassis ground) so I suppose all measurements on primary side of PSU must be measured relative to GND_H.
                    IC1 pin 13 voltage = 17.5V
                    See pic.
                    Thanks,
                    S
                    • Maklaud
                      • Sep 2015
                      • 56
                      • Russia
                      #30
                      Yes, all measurements on primary side of PSU must be measured relative to GND_H.
                      Voltage is normal.
                      • Maklaud
                        • Sep 2015
                        • 56
                        • Russia
                        #31
                        Check IC1 ML4824 (12 pin) output signal.
                        VCC_S_R
                        Q3 - Q4
                        D9, D10
                        IC1 ML4824
                        IC1 ML4824 (6 pin) Vdc PC1S (TLP421) IC5(KA431)
                        IC1 ML4824 (5 pin) VS_ON - PC10S - Q21
                        • Maklaud
                          • Sep 2015
                          • 56
                          • Russia
                          #32
                          ml4824 datasheet
                          • scokljat
                            • May 2012
                            • 275
                            • Croatia
                            #33
                            VCC_S_R
                            Q3 - Q4
                            D9, D10
                            IC1 ML4824
                            Well, let's do it step by step.
                            First I'll check voltages on IC1 pins 12, 6 and 5. Right?
                            What do you want me to do with all other mentioned components related to IC1? (VCC_S_R, Q3, Q4, D9, D10, PC1S, IC5, PC10S, Q21) and signals VCC_S_R and VS_ON?
                            Btw, looks we are getting somewhere step by step, right? What is your primary suspect currently?
                            Thanks,
                            S
                            • scokljat
                              • May 2012
                              • 275
                              • Croatia
                              #34
                              VCC_S_R
                              Q3 - Q4
                              D9, D10
                              IC1 ML4824
                              Here are measurements (when tv is ON):
                              IC1 pin 12 = floating around 0.3V
                              IC1 pin 6 = 1.17V
                              IC1 pin 5 = 0.6V
                              All measured relative to GND_H.
                              Thanks!
                              S
                              • Maklaud
                                • Sep 2015
                                • 56
                                • Russia
                                #35
                                And when tv is OFF.
                                IC1 pin 13 =? V
                                IC1 pin 12 =? V
                                IC1 pin 6 = ? V
                                IC1 pin 5 = ? V
                                • scokljat
                                  • May 2012
                                  • 275
                                  • Croatia
                                  #36
                                  And when tv is OFF.
                                  IC1 pin 13 =? V
                                  IC1 pin 12 =? V
                                  IC1 pin 6 = ? V
                                  IC1 pin 5 = ? V
                                  When TV is in Stand-by mode:
                                  IC1 pin 13 = 0.5V
                                  IC1 pin 12 = 0.08V
                                  IC1 pin 6 = 0.016V
                                  IC1 pin 5 = 0V
                                  Thanks!
                                  S
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #37
                                    https://m.youtube.com/watch?v=yE5CrBlsS48
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      There is the link watch the video different model yes however Psu is the same and similar issue. I dont think that the Ml4824 chips are at fault to be dead honest.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #39
                                        The parts that were hanging off the Psu Pcb are the polly caps try heating where they are if not try replacing them they can cause aload of issues.
                                        • Maklaud
                                          • Sep 2015
                                          • 56
                                          • Russia
                                          #40
                                          Scokljat, when TV is ON. VS =?
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
