Samsung UN32F5500 LED TV Backlight issue
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN32F5500 LED TV Backlight issue
    Ahh more crappy failed leds I see it too often. You can use your DMM to test each bulb to see which ones are S/C.
    • siddhu
      • Jul 2015
      • 17
      • india
      Hey, there are 5 led strips with 9 leds on each.
      Is it 200-220 V in Pin 12 input to LEDs are expected?
      • siddhu
        • Jul 2015
        • 17
        • india
        yeah i tested the LEDs with DMM and found the culprit. now im trying to replace.
        • mrhappypants
          • Aug 2015
          • 8
          • canada
          did you order a whole strip and if where? does anyone have the part number for the individual LEDs on this model?
          • mrhappypants
            • Aug 2015
            • 8
            • canada
            well i can't find the spec for these things anywhere... they don't look like the standard samsung 3535 or the 5630.. so i started doing some testing.
            from what i can tell the whole backlight system on this tv (UN32F5500) is poorly designed. From testing I can tell each LED is meant to run at 2.9V.. 3.1V if you really push them, but that is not what is happening. They feed 45 LED's 160V, doing the math that comes out to 3.55V. So it is little wonder why they fail.
            I'm only new to this tv repair stuff so maybe there is something I'm missing here with backlight design and if so I would love some feedback.
            • TTAN
              • Mar 2016
              • 8
              My boss said he had a bad Samsung tv, which sounded like a bad cap, but turns out I'm having a similar issue with the backlight. The unit has 5 bad leds over 3/5 led strips, tested with my fluke117 (via diode+resistance functions) and ~3v battery pack.
              I've measured the power pins 1-16 to the led array. All produce zero volts aside from pin 11: 188v, pin 12: 213v. when I measure min/max it cycles ~+/-14 v. Just an observation Autorange mode seems to light up the top strip while manual does not.
              Am I correct to assume that I can just replace the 5 bad leds? Should I check anything else out? I was thinking one of these http://www.digikey.com/product-searc...1516-1028-6-ND.
              Are there better parts? I usually like to order ~50% more then I need just in case, but 1.69 apiece starts to encroach on my boss's throw it away mentality.
              • TTAN
                • Mar 2016
                • 8
                Repaired all the broken LEDs. After plugging them all into their sockets, connected to just the power supply/inverter, still no love. I was under the impression if the main and tcon board were unplugged, then the backlights should all be lit up. The only power I get in this setup up is the pins listed above. Do I need the main board to be plugged in? I ran out of time today to check that. If my inverter section of my psu is busted, anyone know what the likely culprit is? I wasn't sure how to test mosfets in circuit, but I was fairly certain all the caps transistors and diodes were good. I didn't measure any out of circuit yet, as I was hoping replacing the LEDs would do it.
                Your thoughts would be greatly appreciated.
                  This UN32F5500 power supply-LED driver board should power up the backlights when it is not connected to the main board, it has built-in pull up resistors for self test.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #29
                    Have you double checked your new leds? its so easy to fit one wrong ive done it before.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      +1 I also made a couple of mistakes.
                      • TTAN
                        • Mar 2016
                        • 8
                        Originally posted by siddhu
                        Hey, I opened my TV back panel and there are 5 LED strips.
                        I could see one of those strips is burnt. I have ordered for it, which i will get it in few days...
                        Thanks everyone for your input. When my dmm is in auto range, and I check voltage on the only active pins, the top led strip lights up. I ended up swapping all 5 through the top slot to make sure they light up. The color isn't as blue, but I haven't glued the lens back on yet either. I'm waiting to glue, just in case I blow one. I have a feeling that the led side of the psu has an issue since it doesn't light any of the strips up. So my game plan is to des older and check with multimeter. I've identified all replacement components except the large mosfet as I have difficulty reading the writing on it. Tbh I haven't figured out yet how to measure them to see if they are good or not. I'll write back when I know more.
                        • TTAN
                          • Mar 2016
                          • 8
                          Some updates.
                          I checked my notes, and I realized that I found all the replacement parts, sold in the shopjimmy kit, including mosfets already.
                          http://www.digikey.com/product-searc...t=497-12246-ND
                          http://www.digikey.com/product-detai...186-ND/3152447
                          http://www.digikey.com/product-detai...1-1-ND/3060933
                          http://www.digikey.com/product-detai...0CT-ND/3907888
                          I had time to test components, by desoldering 1 leg.
                          The fuse, tested continuity with low resistance (3 ohms).
                          Resistors, I'll list location, and the measured value, with the listed value
                          RM813 (location) 81.5kohm (measured), 82kohm 5% (listed)
                          R9110 3.5 ohm, 3.6 ohm 5%
                          r9109 0.5 ohm, 0.4 ohm 5%
                          rm801 0.4 ohm, but subseq readings were 0.7ohm , 0.44ohms 1%
                          rm802 0.4 ohm, but subseq readings were 0.7ohm , 0.44ohms 1%
                          Diodes, all were SR(SB) 320, voltage measured in one direction, O.L. in the other.
                          DM858c 0.348v, remeasured at 0.355v
                          DM859c 0.351v
                          DM860c 0.355v
                          I assume everything measured is within spec, If I am incorrect please let me know.
                          I did not have time to desolder the mosfets from the board to see if they are functional.
                          the shop jimmy part kit can be found here http://www.shopjimmy.com/samsung-bn4...repair-kit.htm
                          They also have a hires image of the board, front and back here, which can be used to confirm resistor values.http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
                          Thanks for all the help so far.
                          • victor_cj
                            • May 2015
                            • 90
                            #33
                            I used LATWT470RELZK led to repair the led strips.
                            https://www.youtube.com/watch?v=CCw1Ks4ZBXc
                            The art of fighting without fighting
                            • TTAN
                              • Mar 2016
                              • 8
                              The temp of the LEDs seem to match very well. I couldn't tell which ones were replaced when they were lit up.
                              Thanks for sharing
                              • o0larry0o
                                • May 2016
                                • 26
                                • France
                                #35
                                How do you unsolder the old one and solder the new one back ?
                                the one I have t replace is just next to the connector ...
                                • TTAN
                                  • Mar 2016
                                  • 8
                                  Personally I scraped old the led with soldering iron then cleaned the contact. Use caution as you can damage the contact and may need to rebuild it. When you put the new one on, use flux. It's essential to get the solder to flow under the contacts on the led. LEDs melt super easily, so I wouldnt apply the iron directly to them, let the solder flow into the contacts. Double check polarity first as well. After that I used electronics grade silicone to glue the lens on again. Good luck buy extra LEDs in case you damage the first couple. May take practice.
                                  • TTAN
                                    • Mar 2016
                                    • 8
                                    Just an update on the tv I was working on. I fixed it and it's back in its home.
                                    The leds I used were not a great match for the existing ones. They were more white or yellowish when compared to the purplish factory ones. Even across a single batch there was variability in regards to brightness, and color temp. I assume part of this is due to damage incurred during soldering. I improved my technique by the end. I cannot recommend the LEDs I mention in the previous post. Perhaps if all the strips were redone the color wouldn't matter, but 45 LEDs x 1.2 leds for mistakes at 1 dollar a price makes that not worthwhile. I hope this helps.
                                    • Territup
                                      • May 2016
                                      • 5
                                      • usa
                                      #38
                                      Well my Samsung UN32F5500AFZA Backlights went out yesterday everything else was fine so i opened it up and this is what I have, these pictures are from today. Luckily I unplugged it last night or probably wouldn't be here posting this.
                                      • Territup
                                        • May 2016
                                        • 5
                                        • usa
                                        #39
                                        Sorry about the quality of the photos i used a phone. I will take some with a camera later tonight.
                                        • fuzzyrunner
                                          Samsung LN52B750U1FXZA - Backlight Issue
                                          by fuzzyrunner
                                          Hello All!
                                          So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
                                          02-28-2024, 07:36 PM
                                        • bstewara
                                          Samsung un65eh6000 backlight issue
                                          by bstewara
                                          Hi All,
                                          I have a Samsung Un65eh6000 with a backlight issue.
                                          The original issue was backlight current was present but led strips did not light
                                          I tested the backlights and all tested to be working properly.
                                          I assumed then that the power supply was not sending current to the led strips.
                                          Power supply board part number BN44-00560A.
                                          After checking voltages it appears that current output at connector CNL802 was outputting the correct current 189 VDC on pins 1,2,6, and 8.
                                          The issue then was there was no ground on the connector...
                                          02-17-2023, 03:32 PM
                                        • totof
                                          Samsung UE55JS9000 backlight issue
                                          by totof
                                          Hello.
                                          I'm sharing with those in the know a problem I'm having with my Samsung UE55JS9000T TV, which has a backlight fault with halos of light on the sides (see my photos). This is a model with LED strip backlighting on the sides.
                                          I took the TV apart to remove the panel and noticed that the "yellowish" film on the Plexiglas light diffusion plate was stuck to the LEDs. When I peeled it off, it left marks on the Plexiglas plate, which I cleaned as best I could with rubbing alcohol (see photo).
                                          The result isn't perfect, but it still seems pretty good to me.
                                          10-05-2025, 08:27 AM
                                        • ScHAmPi
                                          Samsung UE48JU7000 screen issue after backlight replacement
                                          by ScHAmPi
                                          Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                          I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                          07-15-2024, 05:41 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
