Vizio SV472XVT HDMI Problems
  • kevinm34232
    • May 2012
    • 1884
    I've had this TV for awhile in the bedroom hooked up to cable box with HDMI 1. Over the last year I've noticed (progressively getting worse), it loses connection with HDMI (No Signal message), mostly when first turned on from cold, but lately anytime. It will start by flashing a black screen and then go completely black after a minute or so. Unplugging HDMI cable and back in will normally make it work again.
    I thought it was my cable box but after trying new HDMI cables, the 2 other cable boxes in the house, and the Playstation 3, I had same problem. All HDMI ports also do the same thing.
    So I'm convinced it's the main board, which had been repaired before (but for bad EEPROM).
    I have to open it back up for some pictures which is a hassle on this one.
    Any ideas what would cause this?
    HDMI Switch IC?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8087
    Re: Vizio SV472XVT HDMI Problems
    what happens if you heat the main board up with a hair drier etc? Check the HDMI connectors over on the main board. If you follow them they should go into a big IC. Try to heat / cool that.
    • sordids999
      • May 2013
      • 2149
      • uk
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • kevinm34232
        • May 2012
        • 1884
        It does go into an IC, I am just asking if that could be the cause of it "not recognizing" or losing the connection.
        • SeaglassPearl
          Vizio E420VA 5v drops to 3v when power cable is connected
          by SeaglassPearl
          Folks, I have a Vizio flat screen that doesn't show any signs of life (and no orange vizio glow either).
          I tested the voltages from the power board (at the connector) and I can see the 5V supply drops to 3V after the power cable is connected to the main board (5V supply reads as 5V when cable is disconnected from main board). All other rails (12V and 24V) are reading fine.
          I looked for the usual bloated caps and saw none on either board and no other tell-tall signs (black marks, burned components, etc) on either side of both boards.
          Given the 5V rail...
          12-30-2022, 05:55 PM
        • aliougm
          Marantz SR4003 AVR HDMI board issue, seeking for help
          by aliougm
          I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
          Connection as below:
          Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
          If I bypassed AVR then HDTV screen color be good.
          I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
          3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
          I replaced all...
          04-30-2022, 12:21 PM
        • howardc64
          Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
          by howardc64
          Failure Symptom
          No Display. Just random blocks of grouped vertical red lines.
          Disconnect right 1/2 panel (rear view), left 1/2 displays properly
          Masking T-Con Signal Diagnostic
          Reduced masking to 5 signals on right 1/2 panel and get perfect picture
          Pins are
          1 GND
          2 VGHD
          3 XON
          4 VSSQ
          5 LC2
          6 LC1
          VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
          Pictures and Schematic
          XON, LC2, LC1 are on AUO s302-21 32pin QFN...
          10-14-2024, 01:30 PM
        • Grasshopper2Ant
          Vizio Flex Cable / Address Bar Repair
          by Grasshopper2Ant
          Vizio V755-G4 LED
          Doing backlight LED strips replace. All good till I decided to clean the screen with the address bar taped to screen.
          I accidentally dislodged the flex cable on the LED screen.
          I was choked after reading it was a pain to repair.
          Anyone out there have a solution for a layman without a bonding machine.
          I saw a square heating attachment to solder iron but have no idea where to get it.
          Any suggestions appreciated.
          I was so close to getting this damn thing assembled.
          08-11-2023, 10:15 PM
        • Ublala Pung
          Lenovo V15 and V17-IIL and probably others with 10th or 11th gen CPU suffer from a design flaw
          by Ublala Pung
          The Lenovo laptops V15 and V17-IIL with I5 or i7 CPU and probably many other Lenovo laptop from this time with 10th or 11th generation Intel CPU suffer from a design flaw regarding the display/camera/microphone connector on the motherboard which is badly placed and the cheapest of the cheap connectors imaginable. As the cable is too near to the display and the connector does not fix it proper in place the cable develops little defects and those over time lead to a plethora of possible quirks or failures starting from the named RAM problem or sudden switching off in special when the display is...
          04-23-2025, 04:47 PM
