help me run these led strips please!!!
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: help me run these led strips please!!!
    ok here are the pictures, the one is the 3 sets of red and black that are coming out from the power supply, then as you can see the way these leds are jumped there wired differently, then here is a pic of the 3 sets of wires coming to the boards. look at the connectors how can I run these to work
      Need the pictures of the whole bottom side of the board, whole top side of the board, closed up the bottom side of the connector to be able to see the traces on that connector. It may be hard to take the pictures due to the fact that the boards are stacked on top of each other, but the setup looks familiar.
      What is the model number of this TV?
      BTW, try to hold the camera still.
      • mattstolte
        • Dec 2013
        • 612
        • usa
          Hmm, the power supply board does not look like your board at all:
          http://www.shopjimmy.com/apex-lk-pl3...upply-unit.htm
          https://www.badcaps.net/forum/showth...180#post579180
            OK, looking at the traces and the pinout of the connector, you are correct that the 3 stings (10 LEDs per string) are connected in parallel, so the total Vf is around 35~40 V range, the filter cap for the boost converter is rated at 100uF 100VDC.
            The substituted LED strip has 8 LEDs per string (4 LED string connected in series to form 1 large string of 8 LEDs).
            When one of the old string went bad (open circuit?) I would expect the other two strings to still light, but if the LED shorted out then all the LED string will be off since the VF will drop down.
            • mattstolte
              • Dec 2013
              • 612
              • usa
              #26
              so how can I wire them to them led strips
                So on the old broken strips connected, one at a time, does it light up and stay lit? I am trying to understand what kind of protection circuit it uses since the amount of the new LEDs is not the same as the old one.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  #28
                  yes If I took the bad strip out the good one would work
                    OK, that means the bad strip is shorted and caused the Vf to drop to below the VF for the good strips to run, but I expect the bad strip will to be on but but not all the LED on that bad strip will light up.
                    It seems to me that since you can run just two strips (same Vf but total current draw) without it going into protection shutdown, it may mean detect the Vf of the string, since the old one had 10 LEDS, the new one only has 8 LEDs per string so the circuit goes into shutdown.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      #30
                      im thinking it is shutting down cause im putting a red and blck intoa connector that is either marked + or - did u see how the end of the connectoprs are labeled amd set up
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        BudM could matstolte put some diodes in series in the wire strings to compensate or maybe a mini-pot to adjust to the correct current?
                          As long as the + (red) represent the Anode and the Black represent the Cathode then it should light up unless there is detection circuit that detects the total Vf of the string, if the total Vf is below then it know that there shorts on one or more of the LEDs, or wire is shorted to GND.
                          So to prove that theory you will need to use 7.5V 2~3W ZENER in series to make it think it has 10 LEDs instead of 8. the Zener will be connected in reverse polarity.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            I'm thinking the 8 Leds are drawing more current. The the LED driver chip I had work on in the Westinghouse 26" TV. had a current sensor input in the chip and if the chip drew to much current then the circuit told the processor and the processor shut the LED driver chip down.
                            • mattstolte
                              • Dec 2013
                              • 612
                              • usa
                              #34
                              budm where should i hook the diode up?
                                There should be a Power MOSFET that the Cathode of the LED strings will be connected to the Drain then the Source pin will be connected to the current sensing resistor, this junction point is then connected to the Feedback pin of the LED Driver IC to maintain the constant current through the LED string by PWM the Gate, so with less LED the circuit may not have enough range to turn on the MOSFET less to too much Voltage is developed on the sensing resistor which then activate the protection circuit.
                                He need to get the IC P/N to look up the spec.
                                  The Zener will be connected in series with the LED string, the + from the board will be connected to the Cathode of the Zener, then the Anode of the Zener will be connected to the + of the LED string which is the RED wire.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Yes this is most likely true as it would think it is going into overload and shut it down before it fries something. If my memory serves me correctly, which I wouldn't rely on, I think the Westinghouse actually sensed the current on the return line to the chip. Whether is was by current going through the resistor or the voltage drop across the resistor I can not remember. Most likely there is and op amp connecter to a A to D converter that then feed backs to the processor. When the processor sees a High or low on that bit it makes it decision to either shut down or keep in on. This would be done on the first start up sequence and then the processor would monitor this pin as and interrupt.
                                    • Ron.M
                                      • Aug 2012
                                      • 27
                                      Dear People;...
                                      It seems that some of you (mattstolte , for example) are wannebe Electronic Engineers !!!
                                      The BEST way to solve this problem is to REPLACE the strips with the CORRECT ones...
                                      This is done by looking ON EACH strip for a PART NUMBER & then searching for a supplier..
                                      Need help with that , just ask !!!!...
                                      My Vizio has 4 (FOUR) different types of strips that are NOT interchangeable...
                                      Subbed , yes , easily remanufactured from recycled crap , HELL NO !!!
                                      I predict more problems will erupt IF you continue along that road...
                                      Trial & error experimentation as you are doing can cause bigger problems than what you started with...
                                      But...
                                      It's your TV....
                                      It's your money...
                                      It's YOUR CALL !!!
                                      GOOD LUCK on your trip !!!!.....
                                      Have a GREAT day & weekend...
                                      Later...Ron.M...
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        You must understand that these LED strips were not available when I was troubleshooting the Westinghouse I had been given. They only became available recently. So want would you do throw the TV out or come up with a way to repair the problem?
                                          BTW, the strip will be USED strip any way not brand new so the chance of failure will be just as bad, so is that the BEST way?
                                          • edugimeno
                                            Help findinf LED strips for TDSystems K32DLT1H
                                            by edugimeno
                                            Hi There!
                                            I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
                                            Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
                                            Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
                                            11-05-2022, 03:36 PM
                                          • eccerr0r
                                            What to do with bad LED strips?
                                            by eccerr0r
                                            I suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
                                            Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
                                            Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original...
                                            10-22-2022, 12:27 AM
                                          • CapLeaker
                                            Crimping CAT7 connectors high failure rates
                                            by CapLeaker
                                            I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                                            Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                                            11-09-2024, 04:11 PM
                                          • h4rdw4re
                                            Grundig 40VLE7131BF led strips doesn't light up
                                            by h4rdw4re
                                            Hi guys,
                                            I have one very old TV.
                                            Main problem I have with this tv is that led strips won't light.
                                            I measured voltage levels, and inverter input is 24V.
                                            other voltages are also ok.
                                            What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
                                            First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
                                            I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how...
                                            10-09-2022, 11:10 AM
                                          • Eniaro
                                            Are USB C connectors standard
                                            by Eniaro
                                            I have a number of laptops with damaged USB-C connectors.
                                            I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                                            I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                                            I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                                            07-24-2023, 03:07 PM
