Goodmans GTV42P5DVBT
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Ahh today I repaired this 42" Goodmans Plasma set from around 2003 failed ipm module on the zsus usual fault on these older Plasmas. However when I got this set observing the sticker on the back I noticed "made in Turkey" this is a Vestel set nothing Goodmans about this. Luckily Vestel were only left to make the external chassis of the tv and the mainboard which is a complete mess of wires but everything els (panel, sustain boards, tcon and psu) is made by lg and Sanken as Vestel didnt have a PDP facility so they got lg to make the screens which come with the sustain boards ect.
    Plugging the set in I hear the ysus prime the panel then proceed to make its buzzing noise however using my sense of hearing moving over to the zsus noticed that it was completely silent, no noise nothing. Checked the vs in fuse and it is open/blown. Started probing around non of the diodes or igbts were shorted, then checking the fuse it goes straight to the vs input on the ipm module so knew that the ipm was blown replaced about 20 of them already very common and almost always on the zsus in my experience ?
    After de-soldering the heatsink which was easy enough with my zd915 and hot air gun. Ipm was some cheap 42" power chip crap that had lots of charcoal around it so defiantly dead wasn't going to pay the £20 for a new chip found another zsus that was almost identical but was a 13C version the zsus I needed was a 13D but the pins were the same so thought mares well try it. The ipm was the exact same swapped it over added new thermal paste, re-soldered installed back into the tv and boom picture although kind of crappy lots of discharge so I lowered all the voltages on ysus and power supply by 1 whole volt and panel is now fine, cleaned all the dust out and closed up the case.
    Funny thing is that this isnt hd but has freeview rarely see this on standard definition tvs however I like the picture quality nice colour and contrast especially for being based off a crappy Vestel mobo also very impressed with the speakers 12w into 8ohms and wow those have some bass for cheap speakers wander if Goodmans made them lol.
    Another mystery solved and another tv saved and out of the trash hopefully get some more years out of it only paid £10 for it and selling for £70 as its nicely built well the lg part is. Thanks for reading note there isnt many photos apart from the sticker on the back.
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • 90Ninety
    Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
    by 90Ninety
    Hello
    Model Code Sharp LC-40FG3141K
    Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
    So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
    07-06-2022, 07:09 AM
  • France_53
    Vestel tv, how to flip the image?
    by France_53
    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
    05-12-2024, 05:22 AM
  • hazi12
    Vestel main board 17MB140TC
    by hazi12
    Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
    Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
    I can send a dump....
    10-01-2025, 01:28 PM
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
