Seiki SE322FS lcd tv powers on fine but no backlight
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have another small project tv....tv was made in 2012
    its real cheap and cheap made led lcd tv so so investing more than a few bucks wont be economically smart
    anyways....its so cheap it has 4 boards built into 1
    power supply...inverter ....main and tcon all on one board
    all caps look fine...
    i have seen on shop jimmy something about eeprom ..that repairs a list of common issues with this tv....including backlight not on issue
    anyone have any experience ...it seems to be a very common issue with this model tv
  • shelby5041
    • Feb 2009
    • 1505
    Re: Seiki SE322FS lcd tv powers on fine but no backlight
    well my first search came up empty on here and 2nd search for some reason i see tons of seiki tvs with no backlight threads so i will look....in the meantime if someone has any input please go ahead
    thanks
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      I had picked up a Seiki SE32fy22 and it had no backlight but could see the no signal on screen with light. Took it down to the leds and one connector was not fully seated. Be very careful with panel going back together if you try this. I chipped the corner of panel and ruined it. So now I have almost new tv with no Lcd panel. Live and learn.
      • CapLeaker
        Leaking Member
        • 8118
        measure the voltage on the backlight. Tell us exactly what is going on. My guess is a burnt out LED.
        • shelby5041
          • Feb 2009
          • 1505
          i will check voltages today later on....that may guide me better......i assume these are designed like the old xmas lights.....if one led burns out ......all the led lose power?.....wait a minute.....u saod burned out led....i thought leds last forever?????
          • shelby5041
            • Feb 2009
            • 1505
            i have torn apart many lcd tvs and many lcd monitors.....ill b careful........i make lights out of broken screen lcd monitors.....have 3 on my work bench at work......and i used 3 led strips from a broken tv under my shrlf on bench...theyvr very bright.......i love recycling
              https://www.badcaps.net/forum/search...archid=4995547
              • shelby5041
                • Feb 2009
                • 1505
                update..i do have 60v going to led lamps....
                • shelby5041
                  • Feb 2009
                  • 1505
                  update....disconnected 1 strip led jumped it out.....now bl comes on minus 1 strip.......looked like suspect bad led on that strip.....
                  now what?
                  • shelby5041
                    • Feb 2009
                    • 1505
                    can i jump out 1 led on strip?
                    • shelby5041
                      • Feb 2009
                      • 1505
                      or can i wire in a led strip from a diff tv.....i have some....or are there diff voltage led strips?......or all require same voltage.....that they put in tvs
                      • CapLeaker
                        Leaking Member
                        • 8118
                        You can either replace the LED with a new one or you can put in a zener diode into the LED's place to "fool" the PSU into thinking all LED's are there.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          thanks.....replacement to costly....and not sure how to do the zener diode....so i jusy removed bad strip and repositioned the remaining 2 good strips and its bright enough...with 2....pic is fine.....
                          tv fixed.....
                          never would have thought bad led.....suppose to last forever.....figured it was ps issue .....its a cheap tv so i will leave as is...it works good......thanks capleaker and others.....when i tested good voltage going to backlight i guess issue was backlight by default
                          • shelby5041
                            • Feb 2009
                            • 1505
                            dont want to risk taking apart again...lcd very fragile.......ill stop while i got a good working tv now......just a tad dimmer but not really noticable.....
                              BTW, you can use 5 1N4007 connected in series to simulate the white LED.
                              https://www.badcaps.net/forum/showthread.php?t=46403
                              • CapLeaker
                                Leaking Member
                                • 8118
                                glad you got her going!
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  yeah....thanks...ill pass on trying to repair the defective led....its not worth the hassle ..and the more i mess in thrre the more chances ill damage the lcd accidentally.the picture is fine withoit the 1 strip.......i repositioned the remaining two to maximize brightness evenly.....
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    here are pics of how display looks when i removed i led strip and respositioned other 2....
                                    not tooo bad
                                    it is a little darker in center where there is no led....but its not bad
                                    looks worse in the photos then in real life due to how camera takes pics
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      one question i have is why is it that when one single led goes bad it causes all the leds to not power on......with todays technology that should not happen...........its like the old day on a string of xmas lights when one goes bad the whole 250 ct string goes off and u have to hunt for the bad one and replace it.....this is outdated technology
                                      why????
                                        They do the series string because it is cheaper, to drive each string (I.E. 4 OR MORE STRINGS) then you need more circuits, but if one string is bad the protection circuit will kick in, it is not much difference than the CCFL, one lamp is bad then whole circuit is also shut down.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • classypenguin
                                          Grundig 55 GUT 8768_55 (chassis gf) Black Screen, powers on and shows backlight
                                          by classypenguin
                                          Hello, I bought a Grundig 55 gut 8768_55 (chassis gf) as a defect ‘black screen.
                                          Now I have started with the basics:
                                          Fuse intact, LED Tester says 123V, BL Cap has 140V, Mainboard to PSU 12V, 24V, 3.3V and 5.2V are avail+able, 12V and 3.3V at TCON (TV has no seperate Tcon)
                                          As soon as I switch on the TV, it shows backlight, but a small grey line which disappears again.
                                          When I tap Menu, the background light becomes brighter. What can I assume is wrong with the TV?
                                          A defective mainboard? Or a software problem?
                                          I would be glad of help....
                                          09-21-2024, 01:07 PM
