Any known issues with 32LG5300 LED TV?
  • berniedd
    • Mar 2007
    • 119
    I've been asked to repair an LED televion 32LG5300 model. Set is fine till it warms up after 20 or so minutes, then the backlight turns off. The main board was replaced twice already for this same problem before, once within warranty and the last one months later at the owner's expense. Is there a design problem or known issue with this model line?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Any known issues with 32LG5300 LED TV?
    Probably failed leds again seen it on the 42" version of this set check if what voltage goes to the bulb connectors.
    • sordids999
      • May 2013
      • 2149
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        Beside up loading the pictures, try reducing the backlights level to about 50% to see if the backlights will stay on longer, I will not be surprised if you have bad LEDs.
        • berniedd
          • Mar 2007
          • 119
          Here you go:
            So did you try reducing the backlights level to see if the backlights will stay on longer?
            • lin4sm
              • Sep 2011
              • 67
              I do not know exactly about this LG model. I have experience with some Toshiba and Samsung (both models had Samsung screen).
              Whenever two LED strips are connected together there are bad connection between connectors. Some connectors even becomes yellowish color.
              In beginning TV working fine then intermittently screen goes black. And after some time TV screen does not light up at all.
              I bypass those connectors soldering wire and TV works fine then.
                Sometimes, the LED fails (die-bonding failure), this is usually intermittent causing the LEDs to flash on and off but after the first fault the set usually turns off the backlight as a protection.
                • SoulFreeze
                  Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                  by SoulFreeze
                  Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                  After repairing the above issue, I realized the following remaining problem,
                  Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                  The computer recognizes headphones are connected and displays a popup in windows
                  Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                  Today, 09:53 AM
                • Nagyesz
                  Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                  by Nagyesz
                  I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                  All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                  How can I extend its lifespan? Could reflow help?
                  It has ryzen 5 5500h, rtx 2050, no soldered ram.
                  Example of the artifacts:
                  03-01-2025, 11:11 AM
                • pwnjuice
                  Bitlocker issues
                  by pwnjuice
                  Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                  Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                  Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                  01-06-2025, 05:33 PM
                • Skgod
                  Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                  by Skgod
                  Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                  Black screen, freeze
                  The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                  When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                  So can anyone tell me what would be the possible cause?...
                  10-16-2024, 08:11 PM
                • duwane
                  A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                  by duwane
                  Hi All.
                  Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                  The issue:
                  Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                  10-26-2022, 07:02 AM
