LG 32LD550 won't turn on - HELP!
    Re: LG 32LD550 won't turn on - HELP!
    "Error pin and?" Error pin and GND pin (or Chassis GND) of the POWER SUPPLY BOARD connector.
    "Are you talking about IC1002?," No, the PWM IC P/N BD9270 is on the bottom side of the power supply board. Look at the pictures of the power supply board bottom side, the service manual does not give any info for the power supply board, you will have to trace out the power supply board yourself, it will be very time consuming since you will not going to find the diagram for that power supply board.
    • MisterD
      • Oct 2012
      • 668
      Make sure all of the mounting screws are tightened down on both the power supply and main board, this is how these boards get there ground connections to the chassis.
      I just repaired a LG 32LD450, would shut off after 15 seconds, had blinking red light, problem found slightly loose ground/mounting screws on power supply board that looks just like yours, get them good and tight.
      • yrn11
        • Jul 2015
        • 31
        • IL
        #43
        Well I've checked it up, it's close to 0 Ohms.
        as for Q405 & R419 as I've written above -
        R419 resistance - is very close to 1k Ohms, it's about 0.9k Ohms.
        Q405 C - E resistance - is also very close to 1k Ohms, 0.95k Ohms.
        Sounds very similar but I've checked them all...nothing..
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          #44
          R419 is a 1k resistor so your measurement of 1k across it is good.
          1k across the transistor may be a problem. From what I saw on your photo, your board does not have R451 or R425 so the only path in parallel between Q405's collector and emitter\ground may come through the PSU board itself.
          Try disconnecting the PSU board and measuring across Q405 collector and emitter again. What is the resistance then?
          -David VanHorn
          • manoftheyear
            • Nov 2010
            • 39
            • Europe
            #45
            Hello
            Might I borrow this thread a bit. I have a TV of the same brand and with many similarities although the model is not the exact same. The layout and the components are pretty much the same, the IC on this on is BD9240F.
            TV goes on and blue led lights on for 5 seconds, then the tv switches off and red led comes. Screen stays black all the time.
            I believe this has something to do with the backlights. Should the backlights light up if I put a jump wire from the 3.5V rail to the PWR_ON and INV_ON? PSU starts but no backlight comes. Does this tell the mainboard is OK?
            How come there's a rail on Power supply marked 20V but on the mainboard it's 24V? Anyway with DMM it is 20V, all the other voltages seem to be within the spec too as far as I know.
            I also tested the R419 that can be found on this one too and it is 1K, which is OK.
            When the TV is on for the 5 seconds. measuring the voltage between the collector, base and emitter of Q405 and the ground I get C = 3.2V, B = 0.62V and E = 0V but all the voltages go up and down like it's trying to start the inverter a couple of times. What might cause this, anyone?
            Here should be the service manual for this one: https://cdn.badcaps-static.com/pdfs/...b64fd020f0.pdf but like I said that one has the IC BD9270, mine was BD9240F.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              #46
              You should start a new thread for a different model or it will just add confusion to the thread already here.
              -David VanHorn
              • yrn11
                • Jul 2015
                • 31
                • IL
                #47
                I've managed to get some time to verify it again, i'm getting almost 1K between C & E once PSU board is disconnected.
                what do you suggest?
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  #48
                  Unless I have misread the schematic, then in that case I would suspect that Q405 is bad, or that the schematic is wrong and R418 is not 6.8k as they say it is.
                  Do you have soldering equipment and skill to safely remove\replace Q405?
                  At this point I would test it out of circuit to see what it measures across C\E, or you could measure the corresponding pads on the PCB with it removed to see if there is any change in the resistance measured.
                  -David VanHorn
                  • yrn11
                    • Jul 2015
                    • 31
                    • IL
                    #49
                    Yes I have, can you please point me to the name of the transistor?
                    I've looked it up on aliexpress and couldn't find anything similar.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5037
                      • New Zealand
                      #50
                      It's a 2SC3052, and going by the 'LF' on the package, it's the -F variant (2SC3052-F)
                      I see them on eBay for example http://www.ebay.com/itm/2SC3052F-SMD...item2ede6625a8
                      There are many other transistors you could probably use too though, like the MMBT3904 or MMBT2222A, which may be easier to get.
                      Of course, you should verify if it's actually bad before buying a replacement.
                      -David VanHorn
                      • yrn11
                        • Jul 2015
                        • 31
                        • IL
                        #51
                        will this do the job?
                        http://www.aliexpress.com/item/2SC30...375273839.html
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          #52
                          Originally posted by yrn11
                          It's the correct part number, so if that seller is reputable and the parts are genuine, then yes.
                          Assuming of course Q405 is bad. You have not told us if you removed and tested it out of circuit yet.
                          -David VanHorn
                          • yrn11
                            • Jul 2015
                            • 31
                            • IL
                            #53
                            well in order to validate it, I've ordered a soldering tip that is small enough...so it will have to wait a bit.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5037
                              • New Zealand
                              #54
                              Have you ever done SMT soldering before? The smallest tip is not always the best. 1mm chisel is good for parts about this size, but I sometimes use my larger 2.5mm chisel tip sideways, as it's only about 1mm thick. The worst are those long and very thin 'needle' point tips.
                              There are a number of good videos on YouTube if you haven't done SMT parts before.
                              -David VanHorn
                              • yrn11
                                • Jul 2015
                                • 31
                                • IL
                                #55
                                Well I finally got all the stuff and replaced it, but got nothing.
                                same V readings are there on Q405 (0.67, 0.04) as for resistance it's now 0.
                                as for resistance I got
                                R419 - 0.9
                                QR05 (C-E) - 0.9
                                Any idea?
                                • darlaw
                                  • Mar 2016
                                  • Polska
                                  #56
                                  possible reason is broken core drive transformer, there are two the same type.
                                  • pajdek
                                    Lenovo Y700-17ISK turn on and off
                                    by pajdek
                                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                    09-20-2023, 02:49 AM
                                  • RdeveLabs
                                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                    by RdeveLabs
                                    To all the members here...
                                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                    05-05-2025, 04:59 AM
                                  • masoksian
                                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                    by masoksian
                                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                    The system does not turn on, there is no post.
                                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                    The problem continues in the same way.
                                    I tried to turn on the Fn key, nothing came to the screen....
                                    02-15-2025, 12:08 PM
                                  • JDC
                                    (SOLVED) Sharp LC-46SB57UN Takes a couple to turn on and then no video.
                                    by JDC
                                    Solution: Replace main board. I didn't in this case and ended up scrapping the TV.
                                    This particular set is known for losing its 5V standby. There are repair kits available for this issue and a couple threads addressing that issue here in the forums. This particular issue addresses the TV taking a few tries to turn on and when it did, there was no video, and nothing lit up. I'm assuming the main board wasn't sending the signal to turn the backlights on. Power switch was tested and confirmed working.
                                    A replacement main board on ebay is around $200, not worth it in...
                                    12-07-2021, 07:47 AM
                                  • zaler808
                                    Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
                                    by zaler808
                                    Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
                                    05-23-2024, 05:17 PM
