cap exploded in a vintage VCR
  • jack black
    • 37
    I procrastinated with transferring my old family recordings on DVD. finally i plugged in the circa 1993 multisystem VCR and heard a pop and saw a flame. the VCR was last used several years ago, could this be a factor?
    A small electrolyte cap blew in the power supply. i have no idea what value and voltage. i searched the web for schematics and nothing showed up (toshiba V-880ms). what would you put in?
    Re: cap exploded in a vintage VCR
    At you need to show us the location of the caps so we can see what the function of that cap is. Any pictures of the old caps and the board?
    Service manual:
    http://elektrotanya.com/toshiba_v-88.../download.html
    • jack black
      • 37
      Service manual:
      you are good, i searched too and even was on the same website but downloaded another, corrupted rar. this zip was good and i found the cap C831, 47uF, 25V, and i actually have a spare one!
      than you, thank you, thank you.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds like the primary got shorted to the chassis.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • jack black
          • 37
          what do you mean? i replaced the exploded cap and plugged the (disconnected from vcr) power supply in. the 1.6A fuse started glowing and another big cap (1000 uf/25V) got hot and swollen.
          another bad cap or f....ed up power supply?
          edit: power supply was not screwed to the metal cage when i tried. maybe that was a mistake.
            Fuse glowed, or blew? Most fuses are about to blow when they start glowing.
            I suspect the power board has a problem with output regulation, maybe the output voltages are too high.
            If it's an old VCR, it's probably a first-generation self-oscillating SMPS, possibly based on a ringing-choke converter. They are known to blow a load of parts when they go bad, so repair can be very difficult.
            • jack black
              • 37
              yeah, i pulled the power when i saw the glowing. i put a new 1000 uf cap and the same problem, the power supply is toast. weird, it worked fine last time i used it.
              question, if i buy used toshiba vcr on ebay, will it have similar power supply? the reason i'm trying to save this one, some of my tapes are recorded on PAL camera and this is the only one that can play them.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Sounds more like an irregular waveform. I would get an oscilloscope!
                Arc A770 16 GB
                • R_J
                  • 9556
                  Those caps are getting too much voltage, I suspect the str-d1706 not operating properly, I would change the caps C812, C813 & C809
                  Then check the dc voltage accross c820, It should be around +15 volts
                  Its possible the regulator ic Q801 is also bad.
                    • 31087
                    i used to repair vcr's
                    if the str hybrid is suspect, then you need to replace all the caps - because one probably killed it to begin with,
                    and you need to meter all the resistors, and check all the soldering because anything stuck to a heatsink probably has cracked joints.
                    when we did beltkit&pinchroller jobs, we always replaced the caps simply because once these things blow, it's a much bigger job than a pre-emptive re-cap.
                    • jack black
                      • 37
                      i measured the voltage. it goes from 28 to 32V in the few seconds before i disconnect power. no wonder the caps blow.
                      looks like i'll be replacing the strd1706 and the related caps.
                      i also noticed the board near d811, d813, and f803 is discolored, probably heat. could bad diodes cause the problem too or be faulty in addition?
                      i have to admit i don't understand how that power supply works at all.
                        • 31087
                        check *everything* before you power it up again.
                        • jack black
                          • 37
                          one more question. there is a piece of wire short (from the factory) in the place of C813. should i leave this in place or replace with a real cap?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Leave it be. A capacitor is an open circuit to DC, short only to AC. If there is a wire bridge in that place it means it was never supposed to have a capacitor there in the first place.
                            A working TV? How boring!
                            • CapLeaker
                              Leaking Member
                              • 8214
                              Don't replace factory stuff... just replace those parts that you know are bad.
                              • R_J
                                • 9556
                                It looks like c812 & c813 are in series each is marked as 120uf @25v. I bet the factory installed a 47-100uf@50v in c812 location and jumperd c813.
                                Whats the value of the cap. in c812 location?
                                • jack black
                                  • 37
                                  100/25. you think it should be 50V?
                                  • jack black
                                    • 37
                                    i think i fixed it. replaced C812 with another good 100uF/25V and got 15.5V in the output. the old C812 worked, but with decreased capacity. every other component i checked was fine.
                                    • R_J
                                      • 9556
                                      If the original was 25volt you will be ok. If you have a 50 volt one you could use it instead but its not necessary.
                                      • jack black
                                        • 37
                                        i thought about why there were 2 caps in series. then i thought it's a safety issue in case one of them shorts. somehow the factory ignored it. the irony is the mode of failure was the opposite, loss of capacity and that produced quite dramatic effects, cap fireworks and busted components on the control board that i'm trying to fix. goggling for this shows a common problem in toshiba VCRs of that age. looks like the cap plague existed for a long time before the recent pandemic.
                                        • SolomonMan
                                          Vintage BK Precision 1403 Oscilloscope....
                                          by SolomonMan
                                          All,
                                          Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                          Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                          I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                          12-03-2023, 10:39 PM
                                        • Bivolalbert
                                          Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
                                          by Bivolalbert
                                          Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
                                          Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
                                          02-13-2025, 10:30 AM
                                        • iminusjk
                                          Lenovo Yoga Pro 9 14IRP8 - help identifying what exploded in the motherboard
                                          by iminusjk
                                          I hope this finds you doing well.
                                          I need some help identifying what and how important is that exploded in my laptop's motherboard.
                                          Photos attached.
                                          My laptop is a 1 month old Lenovo Yoga Pro 9 14IRP8 (83BU), i9-13905H, RTX4070, 64 GB ram.
                                          It was in the charger, and I was excited to play FC24 for the first time, but when the loading screen came something exploded in the laptop and it shut down.
                                          It didn't turn on for about 30 seconds after that, but then it turned on and has been working seemingly perfectly (at least I didn't notice...
                                          12-21-2023, 01:30 PM
                                        • DrDos
                                          Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                          by DrDos
                                          Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                          08-08-2025, 03:16 AM
                                        • Satdude
                                          Yamaha RX-479 PSU exploded
                                          by Satdude
                                          Hi, I have a Yamaha RX-497 receiver, and one day I came home to a burnt smell and the breaker was tripped. Upon opening the receiver, I saw extreme damage to the main power board. C254 was exploded, R261 was burnt, D255 was shorted, Q254 is open circuit, D261 (bridge rectifier) is also open, traces to IC252 (TC4013BP) are vaporized right off the board. Not sure about any other damage, I'll have to desolder the flip flop to test it. Also the transformer T251 is getting hot when plugged in. What could have caused such extreme damage just sitting plugged in? Only repair that was done in the past...
                                          04-18-2024, 05:54 PM
