Panasonic Viera P42U10E Replacing buffer board! What to check?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Im having some trouble with this TV. It has a shorted lower bufferboard. Upper board is fine and SC board is also fine. ( did the jumper check and tv stays on ).
    I replaced the buffer board before and forgot to test it and same issue , tv is blinking and board is short.
    I now have a NEW lower bufferboard ( TNPA4785 ) which i want to replace in the tv , what can i do to prevent the board to get shorted to? I tested the new board and it has NO shorts!
    Are there any tests that i can do? Is the panel shorting the board or the SV board shorting the buffer board?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic Viera P42U10E Replacing buffer board! What to check?
    Vsus on sticker is 209V , im measuring also 209V.
    I measured the 4 " iron blocks " ( ZA411 ) where the screws go into and it measured " - 130V ".
    TPVSUS = 208.9v ( ground to test point ).
    TPVSET = 290.8v ( ground to test point )
    TPVAD = -217.2v ( ground to test point )
    TPVSCN = -60v ( ground to test point ).
    Im afraid to place the new board , don't want to brake it!
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      From the service manual :
      Vset
      TPVSET (SC) = 290V ± 9V
      Vad
      TPVAD (SC) = - 195V ± 2V
      VR16600 (SC)
      TPVSCN (SC)
      Vad_base : 148V ± 1V GND_base : - 47V ± 3V
      VR16841 (SC)
      Vda
      TP9 (P)
      60V + 1V, - 2V
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        This tv won't turn on with just the upper buffer board only , still 7 blinks. Is that normal for this set? I read that some panasonic plasma's work with just 1 buffer.
        Also , TPVAD is around -217V on my set and in the manual it says it has to be around -195V. I tried to alter the voltage with the correct pot meter as shown in the manual but it won't drop to -195. It just stays on -210/217. Is that because the buffer boards are not connected? Btw , all voltages are without the bufferboards connected.
        Test point 9 on the PS is 60V so everything looks good but im afraid that if i install both bufferboards that i get the 7 blink code again due to a bad panel. Panel and tabs all look good.
        I hope that someone can verify that my voltages are ok and that i just need to install the boards to see if it works or not........
        Sorry for all the info , just want to be sure and not break the board!
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I corrected all the voltages including VAD and installed the NEW buffer board.
          7 blinks and the new board is short. This tv is going to the trash.......
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • Noodneek
            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
            by Noodneek
            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
            08-30-2024, 12:52 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
