Technika LCD42-910 Buzzing PSU
  • Wabby
    • Apr 2014
    • 30
    Hi Guys,
    Recently stripped down a LCD42-910 that is making a buzzing noise.
    Straight away saw 3/4 caps that were bulging - One with a hole! Result, or so I thought.
    Swapped them out, and still have the noise.
    Anybody any ideas?
    Im assuming its to do with those diodes up the top, but have no idea how to test them, and they show values in BOTH directions :S
  • sordids999
    • May 2013
    • 2161
    Re: Technika LCD42-910 Buzzing PSU
    Take one leg of the diode out of circuit and measure again,and im thinking the buzzing noise is coming from the picture i have uploaded ?
    • Wabby
      • Apr 2014
      • 30
      Yes from that area. Any ideas?
      I will pull the diodes out and test.
      • Wabby
        • Apr 2014
        • 30
        Top left circled area ish. Could also be coming from the 3 components under the heatsink in the middle at top
        • Wabby
          • Apr 2014
          • 30
          Anybody else any bright ideas?
          TV works perfect, just this very faint humming noise gets annoying when you 'hear' it because once you have heard it, you cannot unheard it. lol
          • Wabby
            • Apr 2014
            • 30
            Checked and everything seems fine - Shame about the buzzing still though
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              These power supplies do hum because of the poor feed back and oscillation trust me you think thats bad wait till you hear a 17pw25-4 that sounds like a fucking car on a bad day they are the worst, its probably fine yes it might hum but just take your mind off it and dont obsess over it thats when you will notice it. My plasma buzzes and I used to obsess over it but just ignore it recap it fully with good caps for safety you never said but does the set work ?
                • 31198
                wax or epoxy covering the coils may help.
                • Wabby
                  • Apr 2014
                  • 30
                  Yeah set works fine.
                  Will epoxy damage anything?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Epoxy will be fine on the transformers will just muff out the buzzing noise as they normally are the cause.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • stvhop
                      HP1955L Buzzing noise & interference
                      by stvhop
                      Hello, This is my first post so please forgive me if I miss out some vital info.
                      I have a problem with my HP1955L monitor from 2005.
                      The first thing to say is that it is still basically working, ie the picture is fine.
                      However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                      The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                      11-07-2020, 07:13 AM
                    • Orion Bardier Skylar
                      Adding Bluetooth module to Woofer buzzing noise
                      by Orion Bardier Skylar
                      Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
                      03-06-2024, 02:35 PM
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • tony359
                      by tony359
                      11-28-2023, 05:18 AM
