Panasonic Plasma Input Issues
  • ahall13
    • Jul 2015
    I've tried to do some research, so I would like to verify my findings or see if there is a way to troubleshoot further before buying parts.
    I received a 55" Panasonic Plasma (assembled 2008). The screen turns on and I can access all of the menus, but it is not detecting HDMI or component video. I tried two devices and didn't get sound or video with those inputs. Hooking up a coax cable the tv has picture and sound, so it is just an issue with the inputs.
    From my reading I'm gathering this is probably the logic/main board. Anyone want to point me in a direction to troubleshoot more or provide some feeback on my thoughts?
  • sordids999
    • May 2013
    • 2158
    Re: Panasonic Plasma Input Issues
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • Lintesir
      Panasonic P42S30 Plasma - Pink sparkles
      by Lintesir
      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
      There is about a 5cm high region at the top without any sparkles,...
      07-26-2024, 03:16 AM
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
