Vestel LED tvbaz the closing 32ph3125d
  • necatduman
    • Feb 2015
    • 72
    • siirt
    vestel modelno good deeds: 32PH3125D customers FAILURE LED TV said there sometimes 1 or 2 times 3 gündeb sometimes he opens the TV screen beyazlaşıp off and immediately remove the sizzling sound
    those made: supply voltage and full board in my solder cools the refrigerant hooked on görülmedi processor
    I wonder why I ran the workshop makes no problems ear is power kartı17ıps19-4 VI have installed LED TV works as a TV TV is off and the TV is going sizzle TV opens this way is not always the occasional happening ababa t-con panel LVDS kablod kartında my career when there are problems or
  • necatduman
    • Feb 2015
    • 72
    • siirt
    Re: Vestel LED tvbaz the closing 32ph3125d
    I like it I gave a picture of the same fault Vestel LCD Sony LCD , but sometimes dead
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • France_53
      Vestel tv, how to flip the image?
      by France_53
      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
      05-12-2024, 05:22 AM
    • FlailingEngineer
      Help with Bush Tv (Vestel 17mb95m Mainboard)
      by FlailingEngineer
      Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
      Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
      05-31-2023, 06:52 AM
    • hazi12
      Vestel main board 17MB140TC
      by hazi12
      Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
      Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
      I can send a dump....
      10-01-2025, 01:28 PM
    • massimomax
      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
      by massimomax
      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
      spero che qualcuno può averlo per riprogrammare eprom. grazie
      Post in English !!!
      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
      02-28-2025, 07:27 AM
