Phillips 47pfl7642d/05
  • quiggy
    • Aug 2014
    • 136
    I have a quick question, I have a Phillips 47pfl7642d/05 with sound, backlight but no picture.
    I thought it could be t-con and I've not even got as far as taking it out, but I noticed that the slave inverter board has 2 blown caps with clear indications they they're both gone (2 x 35v 680uf). Now, these being blown won't have any affect on the picture being displayed would it? they just control the backlight? which is working.
    I assume the master inverter is why the backlight is still running?
    Cheers guys
  • sententia
    • Oct 2013
    • 269
    • Greece
    Re: Phillips 47pfl7642d/05
    Maybe you should replace those and check all others if possible. Perform a test and take it from there. It is and indication that other caps might have failed as well.
    I am not sure if it would cause no image but there might be feedback from inverter to psu and mainboard...
    • Hamie
      • Apr 2014
      • 1383
      If the backlight is on then it's not them causing your fault.
      Best to replace them thought.
      • quiggy
        • Aug 2014
        • 136
        I thought as much but thought I'd ask, I'll replace them anyway and move on to that t-con when I finally manage to get to it, it's under the metal plate which every other board is screwed to, wonderful.
        • quiggy
          • Aug 2014
          • 136
          Could the control board cause the same symptoms as the t-con? There's sound and backlight just no picture
          • sententia
            • Oct 2013
            • 269
            • Greece
            Have you replaced the mainboard or tempered any settings in service menu?
            You can always try with remote control:
            062598 MENU XXX
            where XXX is the 3 digit number printed on the side sticker of the back cover of the TV. This will reinitialize the panel.
            • quiggy
              • Aug 2014
              • 136
              I've not replaced the main AV board because there were sound so I assumed that would be ok.
              • quiggy
                • Aug 2014
                • 136
                I replaced the t-con and the problem still remains, there is some red pixels I've noticed in the bottom left corner though, not sure what this could mean.
                • reessi
                  Imac A1312 - Blown Diode, Need Inverter Schematic?
                  by reessi
                  iMac 27-Inch "Core i7" 3.4 (Mid-2011):
                  First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
                  Searched all over for one!
                  All voltages to the Inverter are correct:
                  (12v in, 3.3v Enable and PWM Approx 3.0v).
                  Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
                  After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct...
                  12-04-2020, 06:58 AM
                • eccerr0r
                  inverter H tree driver imbalance in an AC inverter
                  by eccerr0r
                  My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                  11-16-2025, 12:34 PM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • x_orange90_x
                  Vizio E55-E1 bad backlights or bad inverter?
                  by x_orange90_x
                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                  I don't know how exactly to test the inverter itself. Is it...
                  01-29-2025, 09:24 PM
                • Gentian
                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                  by Gentian
                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                  03-06-2023, 07:07 AM
