Panasonic TC-P50X3 14 Blinks.
  • xxsuperstreetxx
    • Jun 2015
    • 8
    • usa
    Hi guys, my tv will click three times when plugged in, then will result in a 14 blink code. 14 blinks is defined as: "14 blinks -> Loss of F15V from P bd. P6/pin 10 or A Bd detection."
    Here is the diagram of the tv internals
    I am a novice at repairing plasma tvs, and do not have a volt meter. Checked physical connections from P6 to A6 and seemed fine. Wondering if trying to change the main board is the best bet.
    Also I have a tc-p50x5 with a cracked panel (Panasonic MD50H14C1A Display part number). The internals are different than the x3, but I am wondering if the panels would be compatible (Part #: MD50H15C1A).
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50X3 14 Blinks.
    may get away with it if the board holes will mount up to the panel. have you checked out the SN and Ss boards for shorts though? Not sure about the x3 but in the FHD models 14 blinks is quite often shorted SC(SN) board.
    Not having a multimeter is a hinderance though.
    you could try this. disconnect the following with the Tv off.
    SN2, SS11, P35, the 3 white ribbons at the A board A23,33,34.
    Now turn Tv on and see if it will stay on and no error blinks. If so , turn it off. Do not reconnect anything for at least 5-10mins as voltage will still be present on the power leads from the P-board which can damage the boards and the panel(P35)
    if it passed that test then I'd expect the SN or SS is shorted. If still 14 blinks, well it'd be A or P
    • xxsuperstreetxx
      • Jun 2015
      • 8
      • usa
      Thanks for the reply. I did what you described to isolate the power supply and main board from the rest of the components. Same error code, indicating it must be one of these two boards. Based on panasonic's repair guide the cpu on the main board might be the problem (see pic). I am thinking of heating up some the chips in an attempt to "reflow" any solders that might have cracked. Maybe this will fix the problem as no visible issues can be seen. I don't have anything to lose as i can't find a replacement board for this tv and they are $150 if in stock.
      • xxsuperstreetxx
        • Jun 2015
        • 8
        • usa
        Any idea what chip could be the standby cpu rom? (there are two chips under the heat sink).
        • Terryfictv
          • Mar 2011
          • 124
          Originally posted by tw2005
          Not having a multi-meter is a hindrance though.
          Best thing to do is buy a simple multi-meter for $20.00 !
          Then proceed.......
            14 blinks is not usually main board. it's usually something shorted tripping main board fault but very rarely is main at fault.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • Biruslapio
              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
              by Biruslapio
              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
              02-16-2021, 09:44 PM
