Unit was fine then the other day no video, no menu but backlight is there, I know it is the video board but can itbefixwd
Samsung 47UN5300d/F7
Tags: None
Re: Samsung 47UN5300d/F7
How about the pictures of the back side of the TV so we can see how all the board are connected together.
Can you also verify the make and the model number? Samsung 47UN5300d nothing comes up.
Did you check the DCV at both end of the SMD fuse on the T-CON board with ref to GND?Last edited by budm; 06-25-2015, 11:23 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
That model number doesn't yield any search results. Are you sure that's the correct model number?
this is the only elektrotanya manual result for a Samsung 5300
Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
my apologies, I received 2 TV's and got them mixed up, the model of the one in question is a Samsung UN32EH5300FXZA WITH THE VERSION NO: UU02, has power backlight and remote functions but no video and no menu, it has a power supply module, a video (Digital PCB) and a buffer scan pcb for the panel, I heard something about reloading the EEprom to bring them back but I like to be patient in case someone has seen this before, thanks and sorry for the errorComment
Have you checked if the tiny fuse(s) on the tcon (buffer scan pcb for the panel as you called it) are open?
Have you checked all the voltages leaving the power supply to make sure theyre within spec?
Please post pictures of the mainboard and tcon.
The manual I linked earlier does apply
You should probably start with the troubleshooting section and follow all their steps to discern whether the problem is the tcon or the mainboard.Last edited by cashkennedy; 06-26-2015, 03:26 AM.Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
- Loading...
