Panasonic TX-P42S30B Possible Bad Panel?
  • Hamie
    • Apr 2014
    • 1383
    I have this Panasonic Plasma basically it had a bad Y-sus or SC board whatever you want to call it.
    Identical to this fault in one of Norcals videos.
    https://m.youtube.com/watch?v=uIyHr13b5w8
    I checked the sn2 connector for short to ground and it was 0.2ohm.
    So I checked q401, q402 q421 and q422
    All shorted,
    also d401 and d421 and the 4 resistors.
    Both d401 and d421 tested fine and the resistors were 7.5ohm as lablled.
    So i installed 4 new igbts and powered on the TV. It appeared to work (I didn't have time to check the picture but the screen definitely turned on as I could see the reflection)
    But after about 4 seconds it clicked off, now it's back to the 7 blinks again.
    I assumed that I must have missed something and checked for shorts, all the parts still test ok and SN2 connector is 2.9M ohms rather than 0.2 so appears to be good.
    Anyway I tent to avoid tvs with silly blink codes. So wondering if anyone who's familiar with panasonics might know of any other faults or tests that can be done to determine if the board is working and it's the panel itself causing the fault.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic TX-P42S30B Possible Bad Panel?
    I did one the exact same the other week, there is a small ceramic capacitor that is near the igbts replace that as it goes leaky. If you look on youtube for Maxxarcade he has a video called panasonic plasma tv repair thats fairly recent that shows everything to replace on this board.
    Also check that you seated all the ribbon connectors that go to the screen correctly they are very hard to get in properly.
    • Hamie
      • Apr 2014
      • 1383
      Cheers I'll check it out.
      Pretty sure I had the ribbons in correctly but no harm in reseating them.
      • flocko
        • Nov 2012
        • 1121
        • uk
        Have you checked the DG302s these go leaky some times not all ways short? IC502 and Q531 I have found in 8 out 10 repairs need replacing, and have you checked buffer ICs as these also fail and are hard to replace. I do an exchange repair service for this board on eBay but bo not take exchange if it has been worked on Flocko
        • Hamie
          • Apr 2014
          • 1383
          I noticed that both the ic501 and q531 were in a repair kit, but couldn't find a part number to check if they were defective.
          I'll check the DG302.
          I've checked the IC's by placing probe on ground screw and running other probe down both side of the rails. Didn't get a short.
          As i say the TV did power up, for a few seconds. I'll see if ohm supplies will do me a deal on the kit minus the igbts.
          • Hamie
            • Apr 2014
            • 1383
            Also the capacitor reecyburger mentioned without a schematic i don't know what the rating is.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              So did it test bad ?
              • flocko
                • Nov 2012
                • 1121
                • uk
                You will not see short to ground ? you use floating ground for buffer IC testing ? test point TPVFG just above buffer IC4805. IC502+Q531 test to ground all legs should read M ohm or OL any low ohm readings show to be faulty. Did you get green LED alight top right when set powered on ? have you tested all SMD diodes and IGBTs ? with Panasonic boards if you do not get them right first time you will for sure blow other components
                • Hamie
                  • Apr 2014
                  • 1383
                  Ok so I've had a bit more time to go over this board.
                  The bottom buffer has a short.
                  There's a bunch of smd diodes that are shorted on the "buffer board" section.
                  any good ways to get the "road tar" off the chips?
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    that's a pain there are no good ways to get the ICs off let alone the silicon, it goes under the ICs and bonds them to the board. You can try cutting the legs, this is the way TW tried and I think he did get one off clean. you have to make sure not to cut though to deep as the traces go under as well off the sides. And the silicon pulls the pads off as well when you try to remove the body, you can use nail varnish remover to get the silicon softer but it will not help with the underside of the IC let me know how it goes Flocko
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Its easier to just buy a new ysus if the buffers are blown, thats a shame because they are expensive.
                      • Hamie
                        • Apr 2014
                        • 1383
                        To be honest I'd rather try to fix it, learning from mistakes is half the fun!
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Fair enough good luck with it let us know how it goes
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            The ICs you can get from sparedparts trade for under Β£10 or eBay Β£12.49 just take your time , they also do the parts for IC502 and Q531. Flocko
                            • howardc64
                              LG 49UJ6500 LCD panel lighter band that goes away
                              by howardc64
                              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                              02-19-2023, 12:13 AM
                            • triplefour
                              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                              by triplefour
                              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                              tcon is built into mainboard.
                              Only one cable goes to panel boards.
                              there is a cable from one panel board to the other that links them.
                              cost cutting measure that results in us having harder time to diagnose.
                              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                              07-28-2022, 07:59 PM
                            • Storyteller12
                              QN55Q60R Service Menu Panel Help
                              by Storyteller12
                              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                              01-13-2024, 01:57 PM
                            • Ancient1
                              I'm stuck . Panasonic TH-L32U20M panel's boards issue
                              by Ancient1
                              Hi
                              The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                              Actions :
                              1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                              1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                              Obviously the fault is from or on the Right, secondary board
                              2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                              09-03-2023, 03:51 AM
                            • maneatingmonkey
                              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                              by maneatingmonkey
                              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                              03-27-2024, 07:17 AM
