Water inside Panasonic projection tv mystery
  • Doc38343
    • Apr 2015
    • 402
    I have this older rear projection and it has been in DRY storage for 2 1/2 years.
    I knew the local power company killed the power supply because I was watching it when it happened (surge from mains transformer blowing up)
    I decided I would fix it today but low and behold there are 3 puddles of brownish water on the boards. It dripped out of the cones above that the color projectors are encased in. What the heck??? It has been dry from the time i unplugged it.
    Mystery to me but i am not even sure I want to try and fix it now.
    Thanks in advance but has anyone seen this before?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Water inside Panasonic projection tv mystery
    My guess is that's glycerin or Ethylene Glycol (they used both) from the projector lenses. Its reaching EOL very fast. Also, if they dump the rest, it won't come out of your carpet.
    Follow the white rabbit.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      It's not water.
      http://opa-and-granna.blogspot.com/2...k-of-that.html
      Extreme temperature swings while in storage helped force it out, but they were always leakers to begin with.
      In addition to a coolant change, those boards need to be completely cleaned of the stuff. Otherwise, the power supply and deflection/HV out will burn up.
      Beware that some CRT assemblies are held not with screws/springs, but torsion rods. If that's what you've got, you'll think you can open and clean the CRTs/chambers, but you'll never get them back together. The tension is too strong and jigs are required.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • Doc38343
        • Apr 2015
        • 402
        Originally posted by kaboom
        It's not water.
        Hey thanks to both you guys makes sense now. In my mind I would say it is nowhere near worth the trouble to repair... I will likely pull the boards for salvage, any other Ideas out there Id like to hear... the waste truck runs on thursday
        Doc
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Doc
          well you could... never mind. not everybody can pull a Photon.
          • Doc38343
            • Apr 2015
            • 402
            Yup!!! especially me..LOL I'm way better at de-soldering and salvage! Soldering iron and air compressor and the parts literally fall out. (youtube trick I learned from a German kid and really saves the part from too much heat as well)
            Seriously??? Photon???..... possible Tennessee target practice sounds way more fun!
            HOLD UP! WILL PHOTONS EXPLODE WHEN SHOT?????!!!!!!!!
              • 31092
              why not just drain and refill the coolant?
              it used to go foggy on the blue tube over time anyway.
              (must be organic)
              • Doc38343
                • Apr 2015
                • 402
                (must be organic)
                Hey I'm game for learning and not wasting.... It was a great TV until the PCompany blew it up by overloading the transformer outside my house... they told me it was an act of God so i asked em why did they tick him off...
                I thought they were razzing me... but if serious,, how can I change the coolant and where would I get it at? (I have no fears cleaning the boards in question)
                At first I thought it was rat pee....
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  (must be organic)
                  If the glycol solution sat on the boards for any length of time, as in the OP's case, I'd be concerned about the fine-pitch traces on that double-sided signal/syscon board.
                  The power/sweep board(s) weren't as prone to that, with their heavier traces, but they must be properly cleaned. Either in a dishwasher or a mild Simple Green solution and rinse.
                  Any residue is conductive, and that silicone around the CRTs' anode connections was a response to a problem. Slow weeping leaks used to make the HV short out, so the idea was to "seal" the HV away.
                  But the coolant still leaked on some of them. I recently gutted a Mitsubishi with better-than-average coolant retention; even so, there was evidence of very slight seepage.
                  I think the drip shields became mandatory by UL spec, after a number of RPTVs had (power/sweep) board fires back in the 80's.
                  EOL it...
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Are any lights getting brighter when large, 120V loads (fridge, washing machine, window aircon, vacuum cleaner) start?
                    Ask neighbors if they've just had any of their electronics blow up. If the POCO transformer, or feeder/lateral/drop to your house lost the neutral, your supposed "120V" goes well above 200V! It depends on the load on each half of the secondary, and if parallel paths are present; also how "good" of a path they are.
                    EOL it...
                    • Doc38343
                      • Apr 2015
                      • 402
                      Sorry dude I moved from there 2 years ago. The distribution transformer blew up (literally like a cannon going off) 5 or 6 times because our power company is independent and have the 3 phase distribution to the homes over loaded. The transformer would literally glow at night in the summer months. (now they finally put another one further up in the easement so it no longer blows up or glows) I bought my home and I am just around the corner from there now but my power is good now it is off a street run.
                      The TV's power supply is bad it needs a mosfet and probably a diode or two. It was turning on but would then cut back off, and in a past diagnosis I found out that it is the power supply. I didn't want to spend the money for a board but now I have learned a bit more and thought i would give it a try actually repairing the board myself. Until I saw the mystery water.
                      I had no Idea the thing had coolant in it... LOL
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Remove the flyback, wash the board, and try again. Bet it stays on with audio.
                        I think you're referring to the open-wire secondary that was overloaded. Old neighborhoods used to have but one transformer, about in the middle, with the 120/240 feed "wingspreading" in both directions. The biggest load anyone had when such developments were built was a washing machine. Maybe an electric dryer, but where power was "scarce," gas dryers ruled (also cheaper per BTU).
                        You probably saw the jumper from the transformer's secondary to the bus glowing, from 4:27 onwards:
                        (secondary bus got together)
                        https://www.youtube.com/watch?v=4nLcjDmGr6g
                        Anything the center tap conductor returns to the TX at this point is of such high current, the "far end" of that supposed neutral rises, resulting in almost the same imbalance as with an open neutral: 120-0-120V ends up as 60-60-120, as measured to a remote "true" ground, like the CATV shield.
                        EOL it...
                          • 31092
                          can you post a foto of the front of the tube and lense.
                          there is usually something sticking out of it like a small bottle to handle expansion when it all heats up.
                          btw, the coolant is to stop the phosphorous on the tube burning because the brightness is so high.
                          • Doc38343
                            • Apr 2015
                            • 402
                            Ours was like this only the final pop was louder.
                            https://www.youtube.com/watch?v=rHVh0KwG_0k
                            It did look the same those insulators. And you are absolutly correct open three wire, the first squirrel killer extraordinaire! Had to be 3 to 5 fried every week and it is still that way today!
                            On my street they can just use the bucket trucks so we get the new fancy tri-plex.
                            • Doc38343
                              • Apr 2015
                              • 402
                              I will try I have to get some actual work done but ASAP
                              It's been sitting there 2.5 years... no hurries, I just hope I can learn a bit.
                              Never worked on one of these before.
                              Seems like a lot of trouble. I will try and get some good photos now that I know better where to look.
                              • kaboom
                                "Oh, Grouchy!"
                                • Jan 2011
                                • 2507
                                That's not a transformer fire. It's either a failing arrestor or broken Chance cutout. It's the fuses that go "bang." They're loaded with a charge that knocks them out, to avoid drawing an arc.
                                This is a transformer fire:
                                https://www.youtube.com/watch?v=7DzVsUdbGwA
                                EOL it...
                                  20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                  by sam_sam_sam
                                  I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                  At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                  Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                  04-09-2023, 08:04 PM
                                • Flaku_34
                                  Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                  by Flaku_34
                                  Introduction:
                                  Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                  04-18-2024, 12:47 PM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                  11-20-2024, 08:52 PM
                                • edugimeno
                                  Stagg sms12p audio amp has water damage
                                  by edugimeno
                                  Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                  I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                  There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                  There is only one signal wire connecting the first boards...
                                  05-24-2025, 06:00 AM
                                • AquaMan Ua
                                  by AquaMan Ua
                                  05-17-2025, 09:40 AM
