Samsung LN46A550 Power Cycling
  • v.i-guy
    • Jun 2016
    • 4
    • canada
    #101
    Re: Samsung LN46A550 Power Cycling
    hello everyone I have the same problem as most guys do that have a 46 Samsung. I got this tv off of a guy for free he said it wouldn't turn on will when I got it home it turned on and worked for a couple of months but once in awhile the right side of the screen would go kinda black brown shady .if I moved the screen or tapped the tv it would go back to a good pic again. will I went to turn it on two days ago and the dreaded flashing red light and clicking. so I pulled the power supply and found that someone had replaced the capacitors but they were not soldered very will they were cold soldered so I resoldered them and put it back in and made a mistake I crossed the two plugins at the bottom of the board cn1808 cn1809. I still don't know I how I could have done that but the tv still came on for about 5 minutes and the picture was great but then it shut down again and back to the dreaded flashing and clicking. so did I fry something else by getting them backwards any help with would be great.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      #102
      switching those doesn't really matter. To me it sound like you either have a bad connection to the ccfl tubes or a bad tube as tapping the tv helped.
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • v.i-guy
        • Jun 2016
        • 4
        • canada
        #103
        thanx for your reply martino. I have looked up ccfl tubes and they say it could be a bad tube or a bad inverter. but would that cause it to power cycle.
        • dreamliner77
          • Dec 2016
          • US
          #104
          Thanks to everyone in this thread but especially budm and Terryfictv! I was able to fix my LN46A550 that had reached the point of not staying on at all through hours of power cycles. I soldered 100uf caps in parallel with C102 and C131 and all seems fine now; it powers on just like it used to many, many months ago.
          budm, first of all thanks for the extremely well documented pictures. Also, it seems that you've done a number of these repairs, have any failed that you've done the parallel fix on?
          • skywkr666
            • Nov 2017
            • 3
            I hate to bring up an old post, but I feel it's ultimately fitting rather than start a new one. This is my 3rd project Samsung; I replaced 102 and 131 with 16v 100uf caps and get a steady 5v at c131; Haven't flipped and reconnected cables to read 102 yet; but would believe to be working just fine. I still have the 8 second cycle click. Thinking about going and replacing cap by cap in the power supply just to be sure, even though I don't believe it to be a problem. Any suggestions whilst I go have a smoke?
            img free
              How did you install the cap positive and the negative leg?
              The original TANTALUM cap has white bar which is POSITIVE, it is opposite from lytic cap which the white stripe is negative. Look at your pictures it looks like you have the polarity backward.
              Look at my pictures.
              • skywkr666
                • Nov 2017
                • 3
                Stripes on my caps are negative; I would've sworn I followed that...I see what you mean, must've spun round in my hand; Thanks! To the iron!
                  Originally posted by skywkr666
                  stripes on my caps are negative; i would've sworn i followed that...i see what you mean, must've spun round in my hand; thanks! To the iron!
                  ok.
                  • skywkr666
                    • Nov 2017
                    • 3
                    I swapped it out for a fresh cap; didn't change anything. :/
                    • Johnny.ricer
                      • Oct 2017
                      @skywkr666 Did you get your TV working? I have this exact TV and have replaced most of the caps on the power supply as well as the two tantalum pad capacitors (C102 and C131). I hear the clicking sound from the relay about every 25 seconds. Any other suggestions as to what to replace/test?
                      • neilc6
                        • Nov 2015
                        • 1550
                        Had a LN46A530 that wouldn't turn on. Relay clicking every 30 seconds. Replaced C102 on the main board and TV turned on. Symptoms when I replaced this capacitor before were green screen and squealing. IC101 is also suspect if replacing C102 doesn't fix it.
                        I then had an intermittent dark area in the middle right area of the screen which could have been an AS15F fault. Replaced it and it was the same and realized it was probably bad tab bonds. Opened up the panel to access the tab bonds and when I turned it on again, screen was all whitewashed. Tried replacing AS15F again a few times and no improvement so probably another panel fault.
                        Giving up and scrapping TV for parts.
                        • keysal
                          • May 2013
                          • 11
                          Picked up a LN40A550 that had bad Power supply caps, replaced them been using the TV for probably over a year. Started to do the start up cycling. checked power supply and replaced any other caps that might be bad. Didnt help, still starts up displays channel and station identity then after a minute or so it restarts.
                          I think I have tried every suggestion in this thread.
                          Purchased new Tantalum caps Kemet brand low esr and the IC's MP2368DN replaced all four items. Still cycles.
                          Tested off board the original tantalum caps and they tested good.
                          Not sure how to test the MP2368DN.
                          Added 100uf electrolytic in parallel with the tantalum. (correct polarity double checked) Still cycles
                          added 47uf with much lower esr in parallel. Still cycles
                          took off the Tantalums added just electrolytic. Just blinking red led now wont turn on.
                          I'm stumped. Not sure what else to check or test or possibly replace.
                          Any suggestions?
                          • dreamliner77
                            • Dec 2016
                            • US
                            #113
                            Has anyone had the parallel fix fail on them? I replaced caps and did the parallel fix 12/2016 and my LN46A550 is starting to show power issues again (power on/relay/power cycle, finally on or occasional green screen). I'm debating if it's even worth opening up again at this point?
                              • 12269
                              • U.S.
                              #114
                              Been seeing a lot of articles about samsung using caps without enough volts for the job required, wonder if that could apply to a lot of these sets?
                              • JunkmanJimbo
                                • Mar 2017
                                • 194
                                Hey budm, does the capacitor have to be a 100uf or can it be a lower or higher value?
                                • tvtimmy
                                  • Mar 2015
                                  • 1160
                                  • usa
                                  #116
                                  Use a 47uf 10v as the designers of the board used. They are cheap as hell on ebay. Order 20 or so like I did and always have spares for repairs.
                                  • JunkmanJimbo
                                    • Mar 2017
                                    • 194
                                    Thank you tvtimmy, I will give it a try.
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      #118
                                      Make sure you get the correct size to fit the pads.
                                      • JunkmanJimbo
                                        • Mar 2017
                                        • 194
                                        tvtimmy, Do you by chance have a link to the capacitors i need to get? Thanks in advance.
                                        • xtrmedia
                                          • May 2011
                                          #120
                                          This work great for my TV set
                                            09-07-2024, 05:50 AM
                                          • high-tech
                                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                                            by high-tech
                                            Hello everybody, I could use some help on this one... It's got me guessing...
                                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                            9. ground (PWM2) 10. 0.9 volts cycling...
                                            09-15-2020, 03:39 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
