Toshiba 46RV525R power supply capacitor problem
Re: Toshiba 46RV525R power supply capacitor problem
Did the main fuse blow also? There is over current situation so you need to check all the power devices to make sure they are OK.Never stop learning
As well, I am assuming, if there is over current, as soon as I put the fuse back (with a good thermister), won't it throw again? How do I check for over current?
thanksComment
You need to check the bridge rectifier, the MOFSET's, etc. Just do the search on how to those devices, the bad device will have low resistance (<100 Ohms) readings between the pins.Last edited by budm; 06-16-2015, 08:49 PM.Never stop learning
Two K4 106 - ???
One W2156 - ???
Two EN220A - ???
I don't know the data sheet so i can't tell the pinout.Comment
Please upload the pictures of the devices.
"I tested the bridge rectifier (D15XB) and it seems to be good" What resistance do you get between the two outer pins? What resistance do you get between the two inner pins?Last edited by budm; 06-17-2015, 10:31 AM.Never stop learning
https://www.youtube.com/watch?v=11JPy4t36oo
When I take the resistance reading, I get the following:
outer pins - OL
inner pins - 0
is the rectifier good or bad?Comment
Two inner pins (AC INPUT Hot and Neutral) showing '0' Ohms? if it is, you need to remove it and test it off the board and also on the two pads of the board.Never stop learning
outer pins - OL
inner pins - OL
out pads on the board - OL
inner pads on the board - 0
The circuit board would lead me to believe that the inner pads should have no resistance between them (see picture below).
I still cannot find any info on the mosfet transistors. Any ideas?
OK, now since I can see partial picture of the bottom side of the board, the two inner pins of the bridge rectifier are tied together that is why it shows 0 Ohms, the bridge is set up as the Voltage doubler circuit.
I need god clear pictures of the whole bottom side of the board.
BTW, the power supply is only $20.
http://www.shopjimmy.com/toshiba-750...wer-supply.htmLast edited by budm; 06-18-2015, 12:42 PM.Never stop learning
I took out the the transistors w2156 and en220a and they seem bad. In diode mode, there are reading below .2 one way and OL the other. Could this be the cause of the over current?
Here is the picture of the whole bottom side:
When I check to see if the device is shorted out of have conduction in both direction, I use Ohm mode on the meter because when semiconductor is bad it does not function as semiconductor any more but more like resistor (conducts both direction).
So take the readings and report the result as in Ohm, or K Ohms, or M Ohms.Never stop learning
I just wanted to add a trick I learned to test if the board is still shorted without wasting fuses. Simply hook an incandescent light bulb in place of the fuse. If you power on and the bulb glows bright, there is still a short!Comment
Or make a box like this if you are going to do lots of repair so you do not have to worry about the clips flying loose from the fuse clips and get shocked or causes damages.
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
Check the resistance between the surge protector VS101 (Close to the bridge rectifier).
Check the resistance between S and D pin of the MOSFETs Q101, Q102.Never stop learning
-David VanHornComment
Assuming...7 Photos -
by chth96hello.
I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
It hardly ever freezed after I finished to recap all of caps in the power supply.
But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
It seems that quality...-
by sam_sam_samThese cheap non brand capacitors at it again
Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
Well at least I have the cameras back on line I to try the... -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
