LG 50PK550 Intermittant Clicking (works sometimes)
  • mostachio
    • Apr 2014
    • 22
    • New Zealand
    Hi Badcaps! I need help please I'd like to fix the above tv.
    I've read lots and lots of info, but please dumb down a lot of stuff for me, I take adequate precautions but i'm still learning as a hobby.
    Symptoms:
    Turn on - immediate reclick of power board trying to fire it up
    Leave it for 45 seconds - it will work, full display, sound everything.
    Leave it a further 15 minutes - It will turn itself off and start clicking again.
    I assume this is a power board problem, there is no visible doming of caps, or any problems I can see. I've read that it may be a problem with AC DETECT signal (there are 5 octocouplers on the reverse) or a specific resistor.
    I have ohm tested all fuses and all ok. I have not yet tested any output from the power board. Be great if I could have some help isolating this! I have an isolating transformer, digital multimeter, soldering station and many spare components / whole boards I can pull bits from (and a 'radio shack' type store to get the ones I don't)
    Please let me know if you'd like any pics or vids
    thank you
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PK550 Intermittant Clicking (works sometimes)
    First of all you need to make sure what board is causing your fault.
    Most of the boards can cause your symptom.
    Unplug the y and z boards from the power supply and monitor the vs and va voltages. See if they drop, or if the power supply continues to cycle.
    • mostachio
      • Apr 2014
      • 22
      • New Zealand
      Hi Hamie, thx for your reply.
      Here are the voltages:
      (Without Y & Z unplugged)
      VS Voltage = 202V on the 2 points on the Y board and on the point Z board connectors
      VA Voltage = 59V on the two points on the Y board connector
      (With Y & Z Unplugged)
      TV no longer hums, barely audible ticking from power board (appears to be tf)
      VS & VA Voltages remain the same
      No voltage varies, and I can't test on the cycle anymore as it is now intermittent cycling :/, did not power cycle with either board unplugged (both & one at a time) and does not do it with both plugged... today. I'm running through a full movie through the HDMI at the moment to see if I can get it to again.
      EDIT: Almost through whole movie, no cycle. I've tried to manually start it cycling but no success. I think it a hazard to leave it on all night to stress test but it does not appear to show fault now... I guess this makes testing a lot harder without being able to reproduce the fault.
      • mostachio
        • Apr 2014
        • 22
        • New Zealand
        I could no longer edit, but update!
        Halfway through the second movie, after it had warmed up, it started cycling again. VA & VS Voltages at 0 (every one) and do not fluctuate, either with Y & Z boards plugged or unplugged.
        • Hamie
          • Apr 2014
          • 1383
          Possibly has a cold/broken solder connection on the power supply.
          Can you upload some photos of the underside of the power supply.
          Photos have to be clear.
          Take maybe 4 photos and label them 'top left' top right' 'bottom left' etc.
          • mostachio
            • Apr 2014
            • 22
            • New Zealand
            That would make sense... I am able to re-flow the back of the board if needed.
            Here are the pics of the rear of the power board etc and some further information, the back of the board was a little dusty, tried to get most of this off.
            Panel P/N: PDP50R10100
            LGIT PCB P/N: 3PAGC10016A-R
            PCB: EAX61392501/10
            PSU P/N: EAY60968801
            Rev 1.3
            I cannot attach IMGs, the popup is not coming up. I have shared a folder on google drive. Link:
            http://tinyurl.com/q5dohjm
            I have also found this badcaps thread of same model & panel https://www.badcaps.net/forum/showthread.php?t=34420 (i cannot hyperlink either..) with exactly the same problem. No further updates though to whether he fixed it or performed the alignment though.
            • Hamie
              • Apr 2014
              • 1383
              Well nothing is jumping out at me.
              Usually coils, transformers and anything attached to a heat sink can sometimes suffer from bad solder.
              This is a common fault with this board that involves the 2 wire wound (22ohm I think) resistors located top right of your board, look like white blocks.
              But your fault is completely different form the fault that they usually cause.
              You can check them in circuit they will be either 22ohm or 11ohm if they are in parallel.
              • mostachio
                • Apr 2014
                • 22
                • New Zealand
                No worries, thanks for your help anyway.
                The top 3 white resistors are RWS-5W 10R0JSMT and all three measure at 10.5~ohm +- .1
                Short of buying a new power board just yet I think I might go over all of the rear solder points except the smd stuff and try that aligning method with the VR's for VA & VS (as they are both a tiny bit undervolting the panel. Panel voltages being 203 VS and 60 VA). I figure 204 and 61 to completely rule out any undervolting issues (pulling at strings a little here).
                Will keep updated if I get it going (even if I have to buy a new board). Cheers
                • Hamie
                  • Apr 2014
                  • 1383
                  Found a more likely cause for your fault.
                  The description describes your fault almost perfectly.
                  Get a hair dryer and aim some heat at this chip and see if your fault occurs faster than usual.
                  • mostachio
                    • Apr 2014
                    • 22
                    • New Zealand
                    I'll give that a go. Despite it being <10C here (New Zealand) the fault occurred almost instantly this morning so is really intermittent (compared to the 3hrs~ the other day) so I can't really say for certain whether or not the IC caused the drop most times while testing...
                    I have adjusted VS & VA to 204 and 61 to no effect, have not done any solder joints yet. But I wonder if heat.. is causing bad solder joints to open on that IC vs a faulting IC. I'll go over the solder for IC & rear of board anyway while i'll i'm waiting for some stability to test with heat gun on very very low heat.
                    Edit: I actually don't have that exact IC on rev 1.3 board, I have
                    V1_1A-1A83
                    F431SMSF11
                    1011 KOREA
                    Ok, so resoldered IC, Transformers, Transistors, Resistors (double would white ones), and any potentially suspect joints I could see. I also checked ohm rating on the other white double wound resistors and found:
                    Two identical resistors : MPR-5W R030JSMT , in parallel have different ohmage ratings and far different than identical resistors on the board.
                    And I have to just double check I'm checking ohmage right. I have it set too 200 in the ohms scale on my multimeter (200, 2k, 20k, 200k, 200M). The same resistors at other points in the board measure 0.5 which I assume 5ohm. These resistors in parallel measure:
                    R607 - 65ohm
                    R613 - 50ohm (or 5.~ on multimeter)
                    (and now they're back to 0.5 without any change in what I did )... Don't know if I just picked up a fault there or not... Resoldered their joints and am about to re-test.
                    Fail. I can hear it reclicking in the lounge after about 1 minute.
                    • mostachio
                      • Apr 2014
                      • 22
                      • New Zealand
                      Update: Testing all diodes for wrong way continuity *uh hope that makes sense* and found diode D304 to be a completely open both ways (this is testing on board).... I'm going to de-solder this and re-test but I think i've found the/a problem... No is fine off the board, bad logic on my part. reading 188 and non-continuity. Have put back. Funny how this was the only diode to show a short back the the other way on board though... The three items that separate this connection are a resistor, that diode and a smd cap on the rear of the board. The Resistor beside it (Orange, blue, silver, gold, black) i've used a colour calculator to find out the ohmage (0.36 O), it tests at 8 O.. (or 0.8 on the 200 setting on my multimeter)
                      • mostachio
                        • Apr 2014
                        • 22
                        • New Zealand
                        Update FIXED: D304 open both ways led me to finding IC301 regulator to be faulty. Replaced IC301 (3BR1565JF Regulator) & for the hell of it D304 diode and fault gone. Thanks for all the help
                        • mostachio
                          • Apr 2014
                          • 22
                          • New Zealand
                          Scratch that it faulted again. 3 months continuous good usage though. I've ordered another IC301 (3BR1565JF) but any idea why it could be doing this? I added good quality thermal grease with installation etc...
                          • lesjones
                            • Feb 2014
                            • 9
                            Let me know if that fixed it again. I have one that has the same problem. Thx!
                            • mostachio
                              • Apr 2014
                              • 22
                              • New Zealand
                              Will do, the ebay seller replaced it free of charge and i bought from a 'reputable' firm too just in case there's some kind of quality issue with them. Will use the latter first lol. Great tv though
                              • mostachio
                                • Apr 2014
                                • 22
                                • New Zealand
                                Nope, not fixed... maybe it was the diode? will replace and update again, all the white resistors still test ok. Apart from that I'm at a loss as it was fixed for a long period and now.. while still going, after a short while it'll power cycle then again, then continually click. Let you know how replacing diode goes.. don't really want to fork out for a new power board..
                                • mostachio
                                  • Apr 2014
                                  • 22
                                  • New Zealand
                                  Tried replacing both the diode D304 (SR104 , 40V, 1A, 30surge A schottky) & the IC301 rectifier again but no go (still same issue). Ohm tested the 3 white ceramic resistors again and they are all fine 10.5-11.1ohms on and off the board. Not sure what to do now except buy a new power board as I can't test the chip mentioned it doesn't stay on long before prior to clicking... and have reached about the extent of my electronics knowledge lol. Thanks anyway
                                  • seraph
                                    • Jan 2016
                                    • 8
                                    • newzealand
                                    Hi I have a similar problem with my set, trying to diagnose before I order more parts!
                                    If I turn it on after being unplugged for a while it'll power up for at most 20 seconds, sometime enough to see the no signal text on screen, but then it clicks off and only click the relays when trying to turn on. Same 3 clicks when everything is disconnected except the ac to psu.I Have checked the 3 10 ohm ceramic resistors and theyre fine, D304 is fine off board, f302 is fine. Does ic301 always take out d304 and f302 when it goes??
                                    Caps all look fine (unsure how to test) all other ceramic resistors read fine.
                                    Anything else commonly go wrong on these boards?
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      • uk
                                      Possible fault:
                                      All supply voltages will come up then die
                                      Intermittent going on and off and clicking
                                      will work for 20 mins then will go off and start clicking
                                      If heating/cooling ic701 makes no difference
                                      check R103,R104,R105,R106,R107,R108,R109,R110,R111,R112,R113
                                      hope this may help
                                      • seraph
                                        • Jan 2016
                                        • 8
                                        • newzealand
                                        Do you happen to know what the values are off the top of your head? I cant read them..
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ex250
                                          Kenwood SW-505D no sound issue and pops from time to time when it works
                                          by ex250
                                          Hello mates,
                                          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                          12-29-2024, 03:27 PM
                                        • jmandawg
                                          LG 42LB5600 standby light works but no picture and clicking sound
                                          by jmandawg
                                          I have a LG 42LB5600 when plugged in the red standby light is illuminated. i can hear a faint clicking sound coming from the part# 14S-LM01 (transformer? in middle of the board) When i press the power button, the standby light turns off but the display does not turn on.
                                          I do get voltages across the fuses and the large caps (did not check the small ones) but no voltage out the led power (top red and black wires).
                                          Did not see any burn marks or bulging caps.
                                          The faint clicking is only when the TV is turned off.
                                          Any ideas?...
                                          08-05-2020, 07:03 AM
