LG 50PK550 Intermittant Clicking (works sometimes)
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: LG 50PK550 Intermittant Clicking (works sometimes)
    R103,r104=240k
    r105,r106=150k
    r107=100k
    r108,r109,r110=680k
    r112=620k
    r113=560k
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
    • CapLeaker
      Dell ATX PSU won’t start, but forcing it works fine?
      by CapLeaker
      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
      10-28-2024, 06:59 PM
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ex250
      Kenwood SW-505D no sound issue and pops from time to time when it works
      by ex250
      Hello mates,
      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
      12-29-2024, 03:27 PM
