Baird TE-40LED AL no standby light
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Hey guys! Been a while since I last posted, I decided to take some time away from attempting to repair TV's. But, I couldn't stay away and here I am.
    Now I've had myself a Baird TV donated which I was told came on after a while but turned itself off 5 minutes later. I assumed caps when they told me but when I got it, I had no life at all, not even a standby light.
    I thought it could have been the PSU but I checked standby and it came back at 5.06v so does that lead me to perhaps the AV board? since the standby light isn't coming on.
    Is there anything else that could be causing this? or what should I check?
    I'll upload pictures shortly
    Thanks!
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: Baird TE-40LED AL no standby light
    if the standby light isn't coming on so that lead perhaps the main board is faulty
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      That's what I thought, since the 5v is there for standby but there is no light. Do you know of anything else to check to be sure?
      • ammarben
        • May 2013
        • 63
        • algeria
        try to start the power supply whithout the main bord
        jump ps_on to 5v with 1k resistor if all voltages came on
        • ammarben
          • May 2013
          • 63
          • algeria
          post model of PSU
          • sordids999
            • May 2013
            • 2161
            Does it use the main board T.MSD306.9A ?
            could be the eeprom
            • ammarben
              • May 2013
              • 63
              • algeria
              it is not a symptom of an eeprom
              wait for an other answer from tom and budm
              • quiggy
                • Aug 2014
                • 136
                • United Kingdom
                I can't find a make of the psu looks like vestel one that I've seen before. I've added a picture of the psu and the main av board too
                • ammarben
                  • May 2013
                  • 63
                  • algeria
                  model bsfp4120-001a
                  • zomi
                    • Nov 2011
                    • 511
                    On the power board have you checked the diodes
                    And resistors
                    Also check the big caps to see if they have any residual voltage before proceeding to check the components..
                    • quiggy
                      • Aug 2014
                      • 136
                      • United Kingdom
                      The big resistor at the top of the psu I can't seem to get a reading from. Would this cause the fault? I wasn't sure how to read this resistor, the green band at the end kept throwing me off, but the only way I could make sense of it was to ignore the green band and it would make it a 0.1ohm resistor? it does measure at 0.3ohm but I'm not sure I've tested it correctly.
                      All the diodes appear fine.
                      • quiggy
                        • Aug 2014
                        • 136
                        • United Kingdom
                        Anyone any ideas?
                        • quiggy
                          • Aug 2014
                          • 136
                          • United Kingdom
                          I'll go ahead and order the main av board and see what happens.
                          • quiggy
                            • Aug 2014
                            • 136
                            • United Kingdom
                            It wasn't the main board.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5095
                              • New Zealand
                              Check for shorted\stuck buttons on front panel
                              -David VanHorn
                              • quiggy
                                • Aug 2014
                                • 136
                                • United Kingdom
                                The buttons were fine, it turned out to be the PSU which I found strange because even though there wasn't enough power to fire up the tv, the 5v was there and surely that would have been enough to turn on an led?
                                Confusing, oh well it's good to go now anyway.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5095
                                  • New Zealand
                                  That is rather odd indeed, unless there is more to it than just presence of 5v for the LED to work, like some power-good status line from the PSU as well?
                                  -David VanHorn
                                  • matyka
                                    • Jan 2015
                                    • 179
                                    • Uk
                                    Hi, did you manage to get it fixed? I have the same problem here.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Have you checked any voltages on your psu to see if any are missing? ive just read the thread and a replacement psu fixed the issue in this persons tv but dose not mean you have the same fault though there are some cheap psu s online if it is at fault,or if you cant find the fault.
                                      https://spares2repair.co.uk/baird-te...1a#prettyPhoto
                                      • matyka
                                        • Jan 2015
                                        • 179
                                        • Uk
                                        Hi, and thanks for the reply. I just fixed the psu, I only had 4.5v that was the only reading from the power supply.
                                        The fix is very simple in my case, cold solder around the big transformer.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
