philips 42PFL3007/12 CHASSIS MTP9.1E LA
  • xalien
    • Feb 2015
    • 65
    • thessaloniki
    Hi
    I have a pihilips 42PFL3007/12 CHASSIS MTP9.1E LA when start up work 10 s and stop it never can change the chanel, never can remote it ,never can going stand by . I think is problem software please help to given the dump file the memory chip is 24C128
    Thanky
  • vlado66
    • Apr 2015
    • 10
    • SLOVENSKO
    Re: philips 42PFL3007/12 CHASSIS MTP9.1E LA
    Symptom
    SW Overview for TPM9.1ELA Chassis.
    Cure
    DIRECTIONS FOR USE:
    1) Open the attached "#SW_Overview_chassis_version.xls" file
    2) Select (via the filters) the CTN and display combination you are looking for.
    3) In the selected row, you'll find all software available for that model.
    4) Click on the latest software hyperlink and save the file on your computer.
    For more detailed instructioins, read attached "#User_instructions_SW_overview_version.pdf" file.
    IMPORTANT:
    - Always write down the original SW version before proceeding the SW upgrade. This will be helpful, if wrong SW is flashed, or when the set is 'dead' after upgrade.
    - Always use the latest software version. Only use old(er) software versions if explicitly indicated.
    - When using ComPair, be sure to use the latest version of ComPair (downloadable from Philips Service website).
    HISTORY:
    21-Mar-2012: Added new One-ZIP software for 3000H series - T911E_2.02.
    13-Apr-2012: Added new One-ZIP software for 3000H series - T911E_2.05.
    13-Apr-2012: Added new One-ZIP software for 3000K series - T913E_2.02.
    30-Apr-2012: Added new One-ZIP software for 3000T series - T912E_2.01.
    03-May-2012: Added new One-ZIP software for 3000H series - T911E_2.06.
    03-May-2012: Added new One-ZIP software for 3000T series - T912E_2.02.
    • xalien
      • Feb 2015
      • 65
      • thessaloniki
      Thanky vlado 66 for your response can you send to me the pasword for this file i can open it
      Thanky
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Wiebotje
        Philips QFU Chassis "UpgradeAll.upg"-file
        by Wiebotje
        Dear members,
        does anybody have the "UpgradeAll.upg"-file that is used in the factory to flash Philips QFU-chassis based TV's?
        09-05-2021, 05:10 AM
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • dawid11931
        File NVM for Philips 55oled707/12
        by dawid11931
        Hello, I am looking for an nvm batch file for Philips 55oled707/12
        02-19-2025, 09:17 AM
      • HP32Sii
        Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
        by HP32Sii
        This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
        The set came into my possession by accident,...
        02-26-2023, 10:00 AM
